I'm looking at doing something like this on an upcoming 50 watt Marshall-esque 2x12 combo amp build.
This has been floating around for a while, and I'm sure some of you may have seen it posted in discussions about adding reverb over at the el34world.com forum.
I like the approach of using an extra gain stage just for the reverb here, and then mixing with the dry going into the PI. The separate power node also seems to be a good idea. The one thing that really doesn't make sense to me though is the 500pF coupling cap on the final stage. That's going to kill some treble (seems to be about -3dB around 2.3-2.4k) on the dry signal through the mixing resistors and the output impedance of that stage. I don't know why you wouldn't use a larger cap here to keep it from affecting the tone. If the person who drew this up did it intentionally, I don't understand why. You could high pass the preceding stage more if needed. Probably should add some low passing too to reduce hiss.
I don't want to get into a discussion here about simpler circuits with less tubes/stages. I want big full reverb, and I'm not trying to cram this into an existing layout. I'll have plenty of room and the heater current to support it.
