Action on 7.25" necks
Discussion in 'Tele-Technical' started by AtlanticCity83, Jul 30, 2021.
  1. AtlanticCity83
    AtlanticCity83 TDPRI Member
    Germany
    Hi,
    What are your preferred setups regarding string height in a 7.25" radius?
    Without choking and buzzing I set up mine in E=2,25mm and 'e=1,75mm.
    Would like to hear about your experiences.
    Greets,
    René
    Timbresmith1 likes this.
  2. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    I have mine set-up the same as my 9.5" with no chocking on the frets, 2/32nds.
  3. Timbresmith1
    Timbresmith1 Tele-Holic
    Central TX
    2mm and 1.75mm
    Too low and I can’t get under the high strings to bend them
  4. EsquireOK
    EsquireOK Poster Extraordinaire
    U.S.A.
    All by feel...but usually around 1.5X factory recommended settings – or at least 1.5X how they are set when they get to me, most of the time. I can't stand low "modern" action; I find it much harder to play on. I find that most factory setups need to be raised by about 2 complete revolutions on the saddle screws, give or take.
  5. AtlanticCity83
    Germany
    Ok, but my setup isn't "too high"? Although it's all a matter of taste but it's a great action to me!
    Telekarster and Timbresmith1 like this.
  6. Timbresmith1
    Central TX
    Nope. Within the normal range.
    AtlanticCity83 likes this.
  7. Telekarster
    Telekarster Friend of Leo's
    Earth
    Same here! ;)
  8. somebodyelseuk
    somebodyelseuk Tele-Meister
    Birmingham UK
    Low E ~ 2.5-3mm
    High E ~ 2mm
    ...on everything.
    Back when I started playing in the early 80s, that was considered a low action.
    I've tried a fair few 'well-known' players guitars over the years and plenty had their action higher than that, none were lower.
  9. TC 57
    TC 57 Tele-Meister
    England
    Most modern Fenders-aside from vintage models have moved away from 7.25" PRS feels 10" is the 'perfect' fretboard radius...
  10. somebodyelseuk
    Birmingham UK
    Yeah, I know, but the radios doesn't dictate my action.
    I have Les Pauls, with 12" radii, set the same, as well as my ESP workhorses, which have 12-14" compounds.
    It's the height I'm comfortable with.
    AtlanticCity83 and Timbresmith1 like this.
  11. wyclif
    wyclif Tele-Afflicted
    Philadelphia
    Usually I start out with Fender's height specs and then adjust from there. This works for me since it gives me a base to start with and then I adjust (usually always up) until the string height is at the point where I can really bang out hard chords with no buzzing. That's how I find the "sweet spot" where the action isn't too low or too high.
  12. AtlanticCity83
    Germany
    Thank you all so far!
    So now I'll check for the perfect pickup height - at least... perfect for me.
  13. jfgesquire
    jfgesquire Friend of Leo's
    Lake View
    Does anyone take a radius gauge to all the strings as a double-check that the saddle heights mostly follow the radius?
    Do you have a numerical method for the 2 through 5 strings?
  14. dreamingtele
    dreamingtele Friend of Leo's
    Melbourne, Australia
    I had this on both my teles. My AVRI 62 and MIJ traditional 60’s. Both were fret levelled, new bone nut and professionally set up.
    [​IMG]Untitled by D Y, on Flickr
    Ignatius likes this.
  15. kinkstah
    kinkstah Tele-Afflicted
    Brittany
    I usually go by feel, but out of curiosity I just measured action on my AVRI 52 (vintage frets, 7.25" radius) ; action at 12th fret is in the 2/32nds ballpark, on both e/E strings (1.5mm on high e and 1.7mm on low E). I do a lot of bends (although rarely more than a full step), without fretout issue. No buzzing either (neck has a small amount of relief, 0.004-0.005"). So it works for me, since I play with a (relatively) light touch, mostly without a pick, and hardly strum. At the end of the day, there is no standard : to each style/player his own setup.
