Acoustic bridge placing question
Discussion in 'Tele Home Depot' started by Chordophonic, Apr 17, 2014.
  1. Chordophonic
    Chordophonic Tele-Meister
    Isle of Wight UK
    OK so not strictly Tele related, however, Im building a CGB with resonator at 25 1/2 inch scale length and am concerned about getting the bridge in the best position possible.
    So ignore the reso bit for now, in your experience how far from the nut would an acoustic bridge be from the nut, I know its not exactly 25 1/2, Gimme a clue boys n girls......
    Regards
    Paul
  2. Chordophonic
    Isle of Wight UK
  3. maumari
    maumari Tele-Meister
    Rome, Italy
    hi paul, I referred to this and it works perfectly on a 25" scale acoustic
    practically the compensation works well at for the center of the saddle sitting at "scale+3,8mm", you can fine tune about 2mm adjusting the saddle top where the strings sit
    hope this helps
    ciao
    Mauro
  4. ElectricNewbie
    ElectricNewbie TDPRI Member
    Denver, CO
    Stewmac calculator will get you close enough for fine tuning intonation on the saddle.
