fmorelli
In a matter of six weeks, we've now had two Fender Acoustasonics come in with bad truss rods. They work fine (threads) but do not alter the neck relief. We are coming to the conclusion that the standard fender-style single action truss rod (anchor/washer at ends of a rod) are compressing the softer wood of these necks (versus hard maple, which does not exhibit this issue). Has anyone else experienced this? The two guitars, under tension, have had between 0.010" to 0.015" relief @ 6th, under tension with 10's. Even using a special clamp jig we have, to counter bow the neck and adjust the truss rod, has no effect (as if the anchor just compressed its way through the neck) - once we relieve the clamp jig with truss rod tightened, we are right back to the same relief.
Given what we are seeing, I am gun shy about recommending replacement tele-style mahogany necks (e.g., WD Music has a licensed Mahogany neck) since I believe the issue is design/materials related. I'm apt to recommend to the owners that they move to a maple neck. Of course both guitars are outside of Fender's very generous 2-year warranty.
Thoughts? Feedback? Experiences? Thanks!
