Acceptable Intonation tolerance
Discussion in 'Tele-Technical' started by SPECTRUM001, Sep 18, 2019.
  1. SPECTRUM001
    SPECTRUM001 TDPRI Member
    Hello - this will have been discussed before (I did search, but couldn’t quite find an appropriate thread).
    Is there an opinion on an acceptable intonation standard with three barrel (uncompensated) saddles ?
    Given that a guitar is not a Formula One car, nor a perfect science and will move with climate and play - I would never expect it to be pure precision. That said, I am coming in a little sharp on the low E, A and G when checking at the twelfth (using a digital tuner) fret.
    What say ye - do you expect perfect intonation ?
    Thanks !
  2. Frodebro
    Seattle
    You’ll never get “perfect” intonation up and down the neck and in various intervals, so the best you can do is set it where it works best for your playing.
  3. POS Guitars
    POS Guitars Tele-Meister
    Los Angeles
    I would care about to low E the least. G is a bit of a culprit, and you might be able compensate at the saddle.
    Regardless, split the difference between the strings on each barrel. It will be good enough for rock’n’roll.
    Piggy Stu and Dismalhead like this.
  4. NewKid
    NewKid Tele-Holic
    Seattle
    James Taylor tunes his guitars slightly flat and says he gets a sweeter sound out of it so I would err on that side.
    I put Glendale brass compensated saddles on my two Teles and I think it helps a little but still not perfect. I also love the way they look.
    nojazzhere and POS Guitars like this.
  5. corliss1
    Lansing, MI
    Set it up - play through some of your usual stuff for a couple minutes. If it sounds good, it is good.
  6. SPECTRUM001
    That’s an interesting thought - tune slightly flat, which would bring strings to pitch as they climb up the neck.
    To be honest, it doesn’t bother me too much, however I am interested in what variation is considered acceptable amongst this community.
    NewKid likes this.
  7. teletimetx
    teletimetx Doctor of Teleocity
    Houston, TX
    many, many ways to get very close. and, yes, there have been discussions ad infinitum here, but just for reference sakes, here's a discussion by Jerry Donahue, who may or may not be your flavor of music, but he's been around telecasters for a good long while, and you can be fairly certain his approach is based on long experience:
    https://www.seymourduncan.com/blog/...donahue-on-telecaster-style-bridge-intonation
    I haven't actually read this whole piece but I would say that his approach finds a lot agreement here.
    I wrestle with the demons in my own way and it works for me. I'm not sure I even do it the same way every time or could not reliably state that to be true.
    best of luck to you.
  8. Bob Womack
    Bob Womack Tele-Afflicted
    Between Clever and Stupid
    My luthier always sets the intonation just slightly flat. Why? With finger pressure you can pull it into tune. If it is sharp, you are up doo-doo creek and can't do anything about it.
    Bob
    NewKid and Nickfl like this.
  9. The Angle
    The Angle Tele-Holic
    Seattle, WA
    Good modern tuners are sensitive to within 1 cent. Sharp human ears are sensitive to within about 4 cents, and most are not that good. If you can get each string to within 5 or 6 cents on two-barrel bridges, you should be fine. Intonation really matters only when you're playing far up the neck. If most of your playing is in the money zone down around frets 1-5, you don't have much to worry about anyway.
    NewKid likes this.
  10. Obsessed
    Montana
    Intonation is only good at the fret you adjust to with only one string being perfect, so don't fret:D about it too much. I flatten my B string regardless.
    I play blues, so a little off is usually a good thing.
  11. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    Don't forget that pretty much everything else on the instrument is a compromise. Even if you get the 12th fret to be exactly twice the frequency of open, the way the rest of the frets fell out might not be ideal. You may, in some cases, want to sacrifice a couple of cents at the octave if it helps keep some of the frets you use more closer to in-tune.
    jjudas and Obsessed like this.
  12. theprofessor
    Chattanooga, TN
    I'd just do it by ear and be done with it. That's what's good enough. I use a TC Electronics Polytune, so it can be super-accurate. But it's the ear that really counts. If you're looking for a baseline of "acceptable," it's your ears.
  13. Prototype
    Prototype TDPRI Member
    The Bible Belt
    When you're messing with it and it's time to eat dinner, you know you're done.
    Telecentric and The Angle like this.
  14. 57fenderstrat
    57fenderstrat Tele-Holic
    Binghamton NY
    It’s never perfect but as close as I can get it. I normally tune my G string alittle flat. When I tune I will fret the A note on the G and tune that note instead of the open string. It makes my D chords sound better but it’s not flat enough to bother me ear when playing a G chord
  15. Bob Arbogast
    Bob Arbogast Tele-Afflicted Silver Supporter
    Lowell, Michigan USA
    I intonate by ear, listening for beating between a reference note and the target note. Close enough is good enough.
    For tuning, I tune my d-string first, then tune d's on all the other strings. (Sometimes I have to adjust the low-e so 3rd fret g doesn't beat against g at fret 5 on the d-string.)
    A critical thing I've found for both intonation and tuning is having nut slots cut as low as possible.
    Grant Austin and The Angle like this.
  16. The Angle
    Seattle, WA
    That's a great way to approach intonation when you don't have a tuner handy! Thanks for the tip.
  17. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Just split the errors. Trust me, nobody in your audience will notice. (That girl who seems to be staring at your bridge is really just checking out how your pants fit LOL)
    POS Guitars likes this.
  18. craigs63
    craigs63 Tele-Holic
    Naperville, IL
    Low E and A are on the same saddle, move it!
    TeleTucson likes this.
  19. Bob Arbogast
    I even do this with a tuner. I find it yields a more overall in-tune guitar than tuning the open strings spot on.
  20. moosie
    Western Connecticut
    Realizing that the guitar is not an equal tempered instrument, and that when one fret is properly intonated, all the others are not... I intonate the 12th against it's harmonic.
    With three barrels, I split the difference. Low E is always sharp, though, and if I let it have it's way, it throws everything off. So, I focus on the A, and then 'give a little' for the E.
    E and B are usually a breeze. G can be very noticeable, and requires attention.
    LowCaster likes this.
