ETMusic777
I have not had a chance to crack open the amp but I will this weekend. I turned on my AA864 Bassman tonight, it was connected to a proper load (Fryette PS100 Power Station attenuator) and the pilot light briefly flickered on, and then went out and there was no sound output. All tubes, including the 6L6s are heating up, and the amp is drawing current so there is power there. The amp is stock except for a replacement Output Transformer, which a prior owner put on there. The power tube sockets have also been changed and its been recapped. The OT is a 2ohm ClassicTone which is actually meant for a tweed Bassman. However I've owned this for 6 months and have played it, and its been great. Before I get in there this weekend, I just wanted to see if anyone had any thoughts on where I should start with the diagnosis? The 2A fuse is fine, and since its drawing power is not a factor.
Im not amp tech but know my way around a schematic, soldering gun and multimeter. Attached are photos of the internals and externals which I took several months ago when I got the amp, they are not current. Power Transformer and Choke are original. When I can get in there, I am going to rewire the 3 prong cord so that it bypasses the aux output totally. I was planning on replacing the OT at some point down the road and will do it now, if needed.
Thanks in advance, amp Gurus!
