For me "ground" has always been just "Zero Volt" and it is where operative current return to power supply when system uses positive voltage power supply. There are systems which also use negative operative voltage, for example fixed bias.
For signal the 0V is a "reference".
First role for Chassis is Safety Earth! Building mains fuse "burn" thru mains cable safety earth wire in case amp own fuse does not protect severe mains current leak to Chassis.
Another role for chassis is a Shield against electromagnetic noise both ways, what amp create and what other equipment and universe create. Thats why it is not good to use chassis for operative current!
Potentiometer case role is also a Shield so no operative current is allowed! When potentiometer is mounted to metal chassis without insulation it turns to a Shield. When signal to potentiometer is wired using Shielded wire the Shield can be soldered to the pot case but when only other end of shield is connected there does not flow any current to Chassis.
When Safety Earth is easily available it is also used to attenuate noise what inevitably form to the signal reference 0V and it is best to do at amplifier input where signal is lowest and amp is most sensitive so 0V is most effective to connected to Chassis at input. Also "ground loop breaker circuit" can be used to connect 0V to Chassis / Safety Earth and when stereo amp system is used obviously other amp should have it? There are good articles in i-net.
