MichelB
Good day,
After playing and modding my Korean made Blues Junior clone, its time to build my own amp.
After trying out a 68 custom vibro champ reverb, I’ve realized this might be my dream amp. Then I got a good deal on a SolandFa vibro champ chassis and a Hammond 290AEX PT (I’m in europe on 240V).
All items are ordered and I’ve decided to go with a JJ 40/20/20/20 cap can solution. Later on a lot reading gave some concerns about the common ground on all those caps inside (more on that)
While I know that a SF champ will use 40/20/20 caps, I think I will remain on the 20uF cap for the main B+ node (for sound reasons). Due to better ripple filtering I will add another filter stage up front, with dropping resistors to get to old spec B+ voltage of 355V.
My proposed power supply will then look as follows:
NOS RCA 5Y3GT - 20uF - 470R - 20uF(feeding OT) - 1kR - 40F (feeding 6V6 screens and vibro 12AX7) - 10kR - 20uF(feeding preamp 12AX7)
This will use the existing cap can and provide better filtering than stock, without putting too much strain on the rectifier tube and keeping the tonal qualities of the original intact. Please comment on my logic if you like?
Then the questions about grounding scheme’s. I read a lot about the disadvantages of a cap can being the common ground of all caps, thus being unable to separate power supply and preamp grounds.
One solution is to simply not use the last cap in the cap can and place another on on terminal strips between the circuit board and the pots, creating a nice starting point for the preamp ground bus (ending at input jack).
The other solution which sound completely logical with a star grounding scheme is to isolate the input jacks, and connect the preamp bus to the cap cans common ground. This makes more sense since it doesn’t force the grounds from the complete circuit to travel via the bus, via the input jacks into the chassis (meaning power tube grounds traveling via preamp and input jack creating noise)
My current chassis contains a brass ground plate and with some imagination I would like to use this into a very good grounding scheme. First of all this plate should be isolated from the chassis (including isolating all pots and jacks as well). The physically close to the cap can I need to connect the plate (acting as ground plane) to the cap can common ground (which is then tied to the PT ct and PT main ground).
On this ground plane It’s probably a good idea to make small star grounds connecting cathode resistor and related grid leak resitors etc.
Can your combined wisdom be shared regarding this proposed layout?
Or is this all theoretical and insignificant considering I use center tapped and twister heater filaments and the amp will likely be quiet anyway.
Regards,
Michel
PS: the remaining build will be documented while I go, currently I’m planning my layout first ;-)
Regards,
Michel
