AA763 Reverb sqeals and whistles
Discussion in 'Amp Central Station' started by heave1, Jun 9, 2021 at 12:48 PM.
  1. heave1
    heave1 TDPRI Member
    Oklahoma City, Ok.
    Just finished a MT AA763 Deluxe reverb amp kit and the reverb seems to squeal after adjusting above 4-5. New tubes and reverb tank. Reverb works great until it reaches that certain point.
    Any advice is welcome.
  2. schmee
    -Try swapping other tubes in V3, maybe V4. What make of tubes are those?
    -Make sure the "grippers" on the reverb cables are tight on the jacks on the back of the amp and tank. Get it squealing a bit and try gripping/rotating those cable ends to see if it stops. Many modern RCA cables dont grip well at all. The old style "all metal" grip tightly.
    uriah1 likes this.
  3. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    There's a 4.7M or a 3.3M bypassed by a 10pF cap that isolates the reverb input from the output. Make sure those are right or you'll get feedback through the reverb circuit.
  4. Roger66
    Roger66 Tele-Meister
    Port Hueneme
    You need to buy another guitar.
  5. King Fan
    Salt Lake City
    I'm not sure PFB causes squeal related to the verb, but it can cause a lot of funky behavior. If simple reverb-sector fixes don't do it, you might swap OT primaries. (Or secondaries. Just not both.)
  6. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    I had a '79 DR that did this at some point, and it turned out to be an issue with a cathode bypass cap that wasn't properly connected. I can't remember if it was the one for the 12AT7 driver tube, or the recovery triode right after it, but it was one of those two.
    After I got the cap properly reconnected, I could max out the reverb with no more squealing.
  7. heave1
    heave1 TDPRI Member
    Oklahoma City, Ok.
    I had the reverb tank too close to the chassis. When I moved it to it's proper orientation, no squeal. I found this out on a post here on TDPRI. Thanks for the help.
    BobbyZ, King Fan and schmee like this.
