A Steinberger inspired "travel" bass
Discussion in 'Tele Home Depot' started by papaschtroumpf, Apr 28, 2021.
  1. kodiakblair
    kodiakblair Tele-Meister
    Scotland
    Built in Germany, those folks are strict when it comes to specs and tolerances.
    Reminds me, need to get my hands on a couple of Bi-Sonics. Is that one from Novak or a Guild/Hagstrom ?
    crazydave911 and ctmullins like this.
  2. telemnemonics
    Indeed it is hard to judge dimensions on unfamiliar assemblies!
    ABM seems to only offer a custom made version of that tuners only assembly now.
    With the growing headless popularity you'd think there would be more hardware options.
  3. telemnemonics
    Yeah some die cast is better than other die cast, zinc is a terrible material though, maybe it's a better alloy.
    Two weeks and it tunes up smoothly?
    Not bad, not bad at all!
    Looks like it mounts right on the body surface with no routing or cutting of body there?
    Could replace it eventually if I like the bass and the bridge wears out.
    Some seem to have a rout in the body they fit into, so a different bridge might need body fixing.
  4. telemnemonics
    With the double ball end you need scale to match string packs, did you go with 34" scale?
    Must be common enough strings.
    For cost I bought a rough ebony blank as this is to be a fretless, really the only reason I'd build a bass rather than buy off the racks.
    Got some maple for a three piece neck and have a few blocks of body wood for something like what @papaschtroumpf is working on.
    I want smaller lighter for my shot back and I like the Steinberger thing, even though Ialways loved Fender P and J basses best.
  5. telemnemonics
    Went to the ABM site and tried several times before successfully sending an email request for pricing on that unit.
    After the first try it switched to all German!
    My Mother came here from Germany via Ellis island in the early '30s but I can't read or speak German...
    I also found some used old stock Steinberger bridge/ tuner assemblies but they are five string.
    Don't need a fretless five string!
    Interesting that you chose an odd 33" scale combined with an extra 3" or so behind the bridge? Are you using double ball strings?
    Seems like that would be a never seen 36"scale double ball set!
  6. ctmullins
    ctmullins Tele-Meister Ad Free Member
    MS Gulf Coast
    This is the DarkStar that I purchased direct from Fred Hammon years ago. The neck pickup is a Novak EB-BS, which is a BiSonic style under a mudbucker cover. Even though they’re both BiSonics, the Hammon is a lot more aggressive (although position has a lot to do with that).
    kodiakblair likes this.
  7. ctmullins
    MS Gulf Coast
    33” is my favorite scale length (well, other than 40” on upright).
    They are standard double-ball strings, which are usually used on 34” scale instruments, hence the extra inch between bridge and tuners.
    telemnemonics likes this.
  8. telemnemonics
    OK thanks that makes sense, I forgot the tuner assembly would go further toward the neck if it was the full built in saddles type, so it's only 1" taken up not the 3" I guessed between tuner and saddles.
    Depending on if and what I hear from ABM I may try the cheap Overlord assembly.
    Could also be making a permanent fretless neck but a temporary/ prototype body to test pickups in and figure out what tuner bridge system I like and can afford.
    I used to have an Alembic fretless I loved the sound of but not the weight, balance, 7 pin cable to PS etc etc.
    The old Stanley Clarke style had a very short body so the neck was far to the left and heading down toward the floor.
    Glorious bwaaaaa sound though.
    ctmullins likes this.
  9. kodiakblair
    Scotland
    No, it's sunk around 6mm deep into the body, think I had 2 runs before getting it right.
    I could have cut a shallow neck pocket but then you're chasing longer screws to secure the neck.
    Since I used my standard 51 template I went with 34" scale strings. Bass Centre Elites were a perfect fit. Once the ball ends slip into their catches it's maybe 3 turns for pitch
    Have La Bella tapes arriving this week, should fit nicely. Both they and the Elites are designed for Steinberger systems.
    I'll certainly report back if they don't fit :)
  10. kodiakblair
    Scotland
    Quick report back.
    La Bella tapes fit perfectly :) Hopefully a shipment of the La Bella double ball end flats land in the UK soon.
    Tweak to the Overlord bridge.
    The provided bridge mount screws have raised heads, those heads can catch the bridge saddles when setting the intonation.
    Replace with flat heads and all is well in the world :D
  11. ctmullins
    MS Gulf Coast
    Rule #1 with cheap hardware: throw the included screws as far away as possible. Use good quality fasteners instead.
    2groggy and kodiakblair like this.
  12. papaschtroumpf
    papaschtroumpf Tele-Holic
    Colorado
    I received the right hardware this time, but there is corrosion/gunk on one of the knobs:
  13. papaschtroumpf
    Colorado
    Well, I finally started the build-proper!
    I used poplar strips, I like poplar and I intend to paint the whole thing. I must say I probably should have looked at grain direction and alternate them, but I didn't think about it and started assembling strips. as you can see the strips are of rather uneven height and I don't own a planer, so I bit the bullet and bought a plane and figured out how to use it. I'm quite pleased with the results in the end, especially for this being my first time. it was quite satisfying to get long curled shavings down the length of the neck when I started.
    I actually cut the body shape and started routing a cavity (going with the triangular shape with pickguard over a cavity). It's not the most compact of my designs, but I liked the shape and the cavity will help with keeping the weight down.
    I forgot to take pictures (I could have sworn I did)
  14. papaschtroumpf
    Colorado
    I need to get wood for the fretboard. I ebonized red oak in my last build but the grain was a little too rough, so I'm thinking walnut. I can only source it cheap in 24" length, and my original plan was to extend the fretboard to the pickguard and have 23 frets, or roghly a 25.5" fretboard
    I wonder if I would be happy with making an "extension" for the last few inches by butting it to the 24" fretboard and still have it look OK
    I need to play with my graphic program to see how it would look with a shorter fretbaord otherwise
  15. papaschtroumpf
    Colorado
    For color, I'm thinking to go with a color-shift spray paint, Krylon, Rustoleum and others make those:
    Not sure about the pickguard, possibly just black
    E-miel likes this.
