A second Acousti-Tele.
Discussion in 'Tele Home Depot' started by Moodivarius, May 4, 2019.
  1. Moodivarius
    Moodivarius Tele-Meister Silver Supporter
    Northwest Ontario
    Getting ready to build another.
    For a 16 year old, who is a distant cousin & a buddy of my 17 year old son.
    Sanded & did the tummy cut.
    The body is one of a few, I aquired from a friend in Wisconsin. He had bought a building, that was previously owned by a guitar luthier. A few routed bodies & partial built necks where left behind, when the guitar shop was shutdown.
    I figured I might as well use this for the next build.
    I think it's swamp ash.
    Not too heavy.
  2. nojazzhere
    Foat Wuth, Texas
    Nice....but how is this an acoustic Tele?.....or is that not what you meant?
  3. Moodivarius
    Northwest Ontario
    tigger, brookdalebill, Deeve and 6 others like this.
  4. Treadplatedual
    Treadplatedual Tele-Holic
    Indianapolis, IN
    Very cool, subbed :)
    crazydave911 likes this.
  5. nojazzhere
    Foat Wuth, Texas
  6. Moodivarius
    Northwest Ontario
    Routed first layer this afternoon.
  7. rickthescot
    rickthescot Tele-Holic
    You do some nice work my friend. Can't wait to see thin one finished.
  8. Moodivarius
    Northwest Ontario
    Well, after routing that one out, I decided that it would be way too light and have extreme neck dive after it was built.
    I had some walnut leftover from a previous guitar body, so I made up a 2-piece blank & a couple of neck blanks.
  9. guitarbuilder
    I think that wood looked like it was Butternut. I made a few teles out of it and still have some of it around here. It's lightweight and fuzzy.
    Treadplatedual and crazydave911 like this.
  10. Moodivarius
    Northwest Ontario
    This is quite heavy.
    Made a Strat body out of other end of the board last year.
  11. Jim_in_PA
    Jim_in_PA Tele-Holic Silver Supporter
    SE PA near New Hope PA
    Butternut ("white walnut") is a little softer than black walnut but not substantially so. I've never seen it to be "fuzzy", however.
  12. Freeman Keller
    From my wood database
    Butternut is easily worked with both hand and machine tools. However, being so soft, Butternut has a tendency to leave some fuzzy surfaces after planing or sanding, and sharp cutters and fine-grit sandpaper is recommended. Butternut glues, stains, and finishes well.
  13. guitarbuilder
    I doesn't sand as cleanly or easily as walnut. Fuzzy is the only descriptor I can think off. It makes you want to wet it and do it again.
  14. Moodivarius
    Northwest Ontario
    Routed out a couple necks & planed a couple fingerboards. 1- walnut neck & 1-Wenge fingerboard for the second Acoustisonic Tele.
    crazydave911, Jim_in_PA and Macrogats like this.
  15. Moodivarius
    Northwest Ontario
    This afternoon, I routed in the truss rod & glued the fingerboard on the neck.
  16. Moodivarius
    Northwest Ontario
    This evening, I made some router templates to inlay the spruce top into the front of the body.
    I took the original Tele template I had, then with a 3/8” bearing bit around the perimeter of the template, it gave me a larger negative of my spruce top inlay. As you see, the shape is adjusted for the forearm contour.
    Then I took that negative, used a 3/4” bearing bit & routed out that, which gave me a template for the spruce top.
    This shows the spruce top template over the Tele body template. I will end up with the spruce top set-in, 3/8” from the outside edge of the body, & the contour route.
    So the plan will be, place the negative on the body blank, with a 3/4” top bearing plung bit, route inside the outer edge, 3/32” deep, all the way around that template. That will determine the thickness of the spruce top being inlayed. Then line up the Tele template over the blank & route body shape.
    After that, I’ll route another 3/8” inside the inlay route, which will be where the body gets hollowed out.
    Sample photo from first build to show the idea.
    This build, I’m eliminating the bridge block, going with the acoustic bridge & bracing on the under side of the spruce top, more like a real acoustic.
    I’m hoping, by making the templates, should save a lot time fiddling around trying to fit the inlayed top into the body.
    I will do a mock-up with MDF to see how it all works. If it does, I’ll be able to make another down road.
    RiversQC, RatBug, Jim_in_PA and 3 others like this.
  17. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    That’s some real cool thinking man. Will be watching this!
  18. Moodivarius
    Northwest Ontario
    More thinking this morning.
    The first route for the top inlay, will have to be a 3/8" bit with a 3/4" bearing to allow the 3/8" offset.
    Scott
  19. Moodivarius
    Northwest Ontario
    Worked on the neck last night. Installed fingerboard.
    Today I trimmed the edges of the fingerboard on the router table.
    Then cut the fret slots.
    Next I sanded the 9.5” radius on my DIY radius sled. Keeps the centreline perfect. Simple, but it works. Only about 2 hours total, to radius fret mark.
    80gt, then 100gt.
    This evening I inlayed the fret markers.
    Sanded them back with, 100gt, 150gt, then 220gt.
    The Wenge is very porous, but smooth.
    Fretting tomorrow evening.
    Scott.
  20. Davecam48
    Queensland Australia
    When I have used wenge I found that it can split along that deep grain, which can give you a nasty splinter in the finger when playing. I always seem to bind my necks these days and "nib" the fret ends which stops that problem and gives a beautiful smooth playing neck action.
    DC
