A reminder to hydrate your acoustics.
Discussion in 'Acoustic Heaven' started by Chunkocaster, Jan 16, 2020.
  1. Freeman Keller
    Google how to calibrate a cheap hygrometer using a saturated salt and water mixture - it should be exactly 75% RH
    Chunkocaster and DHart like this.
  2. DHart
    DHart Friend of Leo's
    Scottsdale, AZ USA
    Good to test, but not all hygrometers can be "calibrated" - but with a known error, you can mentally factor that into what a cheap hygrometer reads. Not a bad idea to have several hygrometers anyway.
    Chunkocaster likes this.
  3. eclecticsynergy
    eclecticsynergy Tele-Afflicted
    Albany NY
    So those Boveda pouches work for a few months and then you discard them - not rechargeable?
  4. DHart
    Scottsdale, AZ USA
    Reading humidity with great accuracy is very difficult, even with the most sophisticated instruments.
    Even if you can calibrate a digital hygrometer to the salt test, expect that the true accuracy of that hygrometer is likely no better than +/- 5% Relative Humidity - which is definitely close enough for properly maintaining a nice acoustic guitar.
    So, if your hygrometer reads 45% RH, it is likely actually somewhere between 40% and 50% - plenty fine, and perfectly safe for the acoustic instrument.
  5. Freeman Keller
    A bit of irony. I build and play (and fix) acoustic guitars and I'm pretty anal about keeping all of mine in their cases and humidified. I have a couple of solid bodied electrics that I keep in cases for protection but I really don't worry about their humidity all that much - ie no sponge/baggie. I took my tele-clone out last night and notices that the fret ends were a bit sharp.....
    Today it went out to the shop and got the frets dressed a bit.
    And, DHart, yes, I know my hygrometers aren't dead nuts on but I know I'm in the ball park (or when I'm out of the ball park). As long as I'm somewhere between 40 and 50 I'm happy, short excursions above or below are OK.
  6. trev333
    Coolum Beach,Australia
    It's about 35C with what feels like 90% humidity after a storm yesterday afternoon/night...
    I'm sure my old Ibanez on the wall beside me is drinking up as much as it needs right now,,,:)
    I broke a sweat typing this post..whew it's sticky,,,:oops:
    telestratosonic and Chunkocaster like this.
  7. swampyankee
    swampyankee Tele-Holic
    Southern New England
    While I was in a rock band and focused on learning covers, my Martin 000C-16GTE lay in its case untouched for maybe a couple years. When I did check on it I found the top was bowed up around the bridge area. I was shocked, and immediately detuned the strings to take the stress off the bridge. It came back, but I've been playing it with light strings and detuned a half step since.
    Now, reading about humidification, I'm thinking it was lack of humidity rather than strong tension that caused the bow?
    I'll get a couple soundhole humidifiers for them just to be safe.
    Sent from my SM-G970U using Tapatalk
  8. Art VanDelay
    Art VanDelay Tele-Afflicted
    Arcata
    I was expecting a meme of a pic of guitars soaking in a bathtub of Gatorade or something.
  9. Chunkocaster
    In space with Ziggy
    In my lounge room in Australia, It averages 50% humidity for most of the year but the air conditioner and fan can still upset things.
  10. Chunkocaster
    In space with Ziggy
    Art VanDelay likes this.
  11. Greggorios
    Greggorios Friend of Leo's Silver Supporter
    Patterson, NY
    Definitely a good idea. Even the good ones have a pretty high fudge factor.
  12. Chunkocaster
    In space with Ziggy
    I have left the humidifier in the sound hole all week with plastic over it, I've been playing it every night and checking how its going. It has absorbed three lots of the dampened foam. Every bit of distortion has gone from the top now and its sounding and playing great with a really low action about the same as on my electrics. I will just leave it on a stand in the hallway if I have the fan or air cond running now.
    telestratosonic and Greggorios like this.
  13. Freeman Keller
    Update from my work bench. About two months ago a guy brought in a GS Mini with a crack in the top running from the bridge to the tail block. He wanted me to fix it and oh, yeah, could I adjust the action - it was a little buzzy. I said no, sent him away with a couple of my sponge/baggies, told him to call me in a month or so.
    Well, called today, brought the guitar back. The crack is tightly closed, the top has a nice little dome to it, the fret plane is right on top of the bridge like it should be. The guitar currently has two of my deep bridge clamps holding two little cross grain cleats under the top, tomorrow I'll clean it up (you can barely tell where the crack was) and restring it. I do need to make a couple of passes on the fret ends and I will check all the parameters, but I would say the guitar is back to perfect health.
  14. OldDude2
    OldDude2 Tele-Holic
    Nashville, TN
    Rain here west of Nashville followed by clouds followed by more rain...I believe we recorded our rainiest year on record. I can't gripe it's white and fluffy up north:p
  15. GGardner
    GGardner Tele-Afflicted
    NJ
    Ok ok. I just guilt-ordered a D'Addario GH Acoustic Guitar Humidifer (sponge insert) and D'Addario Humidipak Two-Way Humidification System for my acoustic. And then impulse-ordered a bottle of Gibson guitar polish. You should get a commission.
  16. DHart
    Scottsdale, AZ USA
    Indeed, fine precision accuracy from a hygrometer is quite unnecessary... as long as you're in the general ballpark, life is good! :)
    I have four hygrometers and two of them read the same, one reads about one percentage off those two, and the forth reads about two percentage off of the first two - when doing the "salt test", range is 72 to 74 %. I'm quite comfortable that any of them is well within reason for gauging humidity of my acoustics, keeping in the 40 to 50% range.
    I do prefer the lively tones from a slightly dryer acoustic guitar, say 38-42%. It seems they start to sound less "alive" over 50%.
  17. Bob Womack
    Bob Womack Tele-Afflicted
    Between Clever and Stupid
    Joe?
    I've been watching the hydrometer. We had a couple of nights of 40% humidity but the temps is coming back up and with it the relative humidity. However, we usually don't get our cold snap until early February.
    Bob
  18. RoyBGood
    RoyBGood Doctor of Teleocity
    Northamptonshire, UK
    It's the cover of ''BUT SERIOUSLY, FOLKS...'', his best solo album, imo. One of those albums that you can play right through without skipping any tracks. I love this record to bits!
  19. Marc Morfei
    Marc Morfei Tele-Afflicted
    Philadelphia, PA
    How important is it to control the humidity for electric guitars?
    I took a guitar for a setup to a new guy, and went on and on about humidification and how dry the guitar was etc. I always keep my guitars in cases, and rarely let them sit out. So I'm wondering how many of us keep our electric guitars in climate-controlled conditions. I'm guessing not very many. But I would be curious to know.
  20. idjster
    idjster VERY grateful member Silver Supporter
    Saskatchewan, Canada
    Wow! You're really lucky! I've seen some real messes from lack of humidity, though I've also seen a couple of real messes caused by leaking humidifying tools in guitars. I guess it all comes down to 'hydrate, but hydrate carefully'. I'm glad there was no serious damage to your guitar!
    Chunkocaster and Greggorios like this.
