A General Guitar Maintenance Question
Discussion in 'Other Guitars, other instruments' started by Paul in Colorado, Jul 15, 2019.
  1. Paul in Colorado
    R.I.P. 2019
    What is the best way to clean a rosewood fingerboard? When I last changed my strings I realized that my Strat neck is starting to get a bit gunky. I don't want to use steel wool. (Magnetism) A liquid cleaner and elbow grease with a rag? What do you do?
  2. lammie200
    lammie200 Friend of Leo's
    San Francisco
    Acetone/lighter fluid works pretty well. Evaporates fast and leaves no residue.
    Fretting out likes this.
  3. chris m.
    Santa Barbara, California
    Even just a lightly moistened, soft rag will do it.
  4. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    I use lemon oil and a clean rag; just don't use too much oil, as it will build up and form its own gunk.
    As far as your (well-founded) fear of metal bits sticking to your pickups, here's a tip: Cover your pickups with blue painter's tape. Use your steel wool for whatever you want to do. The steel bits will still be attracted to the pickups and will stick to the tape. When you're done, use more tape to cover the tape with the metal bits on it. Then peel everything off at once and toss.
  5. Chunkocaster
    In space with Ziggy
    I have used a razor blade before scraping backwards if its real bad, then micromesh pads to remove any marks and applied lemon oil to finish it off.
    Artslap likes this.
  6. trev333
    Coolum Beach,Australia
    I just use that dunlop 65 cleaner.... if there's lots of gunk, a toothbrush might help get all the grunge loose with the cleaner...
    then wipe it all off with a clean rag...
    Andy B and DonM like this.
  7. brookdalebill
    Austin, Tx
    I use lemon oil and an old nail brush, and remove the residue with old, clean cotton rag.
    Works like a charm.
  8. Chiogtr4x
    Manassas Park, VA
    Once or twice a year I will :
    -'dry clean' RW fretboard ( Strat and Martin) and polish frets
    with a teeny wad of 000 ( run it on fret tops/along edges- some filings stick on neck PU, but I wipe off with rag)
    - a few drops lemon/furniture along fretboard just using a rag to work in
    - buff everything out with a clean hand towel
  9. Fretting out
    Fretting out Friend of Leo's
    Land of Mary
    I second just using a moist towel or rag.
    If the gunks really tough then you go to the lighter fluid.
  10. Robert H.
    Robert H. Friend of Leo's
    N. Cal.
    Qtips along the frets
  11. strat a various
    Ouch! Those aren't the same at all. Acetone is a really strong solvent ... it will melt wax! Don't put acetone on wood, it can damage the fibers and one day your fingerboard will be messed up.
    Lighter fluid is like naphtha, which is much milder. Used sparingly, and occasionally, it will clean the fingerboard. Unless it is super dirty, I wouldn't even use that. There's a violin cleaner I use for really dirty necks, it's called Fiddle-Brite. It can be used on lacquer or varnish, and won't hurt bare wood in TINY amounts. Unless the fingerboard has been out in the heat and humidity plus dust and sweat .. I just use a damp terry rag. Just barely damp. Wood absorbs water, and will swell. Oils can deteriorate wood, and it will go soft and develop divots. Use oils, solvents, and even water very sparingly, dry it off thoroughly, and don't use acetone.
    PixMix and lammie200 like this.
  12. Obsessed
    Montana
    Just the slightest dab of lemon oil with a rag once a year during a string change. Rub in well and rubs out the gunk.
  13. lammie200
    San Francisco
    Sorry I meant to say naptha as strat a various pointed out. Brain fart. I don’t buy it anyway because I only ever need the small amount that you can get with a Ronson lighter fluid bottle, but thanks for pointing out my mistake.
  14. strat a various
    Just watching out for your neck, brother. Lighter fluid is OK in small amounts. Some folks use too much.
    lammie200 likes this.
  15. jamesepowell
    jamesepowell Tele-Meister
    Los Angeles
    Like a lot of people have said, a little lemon oil and a rag and some effort. I don't get much hard buildup because I clean the neck every time I change strings. If I needed more than a rag can do, I'd use an old toothbrush.
  16. moosie
    Western Connecticut
    Naphtha is my preferred solvent for guitar work. Use it with a soap-free green scrubbie pad, and scrub the gunk right off. It dries quickly, and dries out the rosewood, so IMHO this is the only time you need to oil the board with mineral oil (so-called lemon oil). Put the oil on medium heavy and let it soak in. Then perhaps one more light coat, and buff it until the board looks rich.
    Naphtha won't hurt any guitar finish, but the scrubbie will, so just use it on the fingerboard.
    Acetone is a very different, much harsher solvent, that I wouldn't get anywhere near my guitars. It's great for melting plastics, like binding, pickguards, knobs...
    Sadly, I just learned that Connecticut is making it difficult to buy naphtha going forward. Home Depot has stopped carrying it here. When I discovered this, I ran over to our last remaining local lumberyard, and scooped up two gallons. Thinking about going back for a couple more. It's on their discontinue list, too.
    Thing is, naphtha is benign compared to so many other readily available products - right on the same shelf. The Home Depot guy pointed to some product brought in as a replacement for naphtha. Main ingredient? Acetone! Yikes.
  17. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    I think Hendrix tried that with somewhat mixed results. Lol.
    Zepfan likes this.
  18. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    I've bought guitars that were a caked on mess. For those extreme guitars I used the lemon oil to soften it and the edge of my pick to scrape. The pick is hard but not metal hard and doesn't marr the wood. You can get right into the fret edges too. Then a little elbow grease to finish off.
  19. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    I find steel wool leaves the fretboard looking dry and you can see the micro scratches.
  20. Artslap
    Artslap Tele-Afflicted
    Sydney, Australia
    Only use 0000 grade steel wool. Everything else is too harsh.
    CP.
    Chunkocaster likes this.
