A few questions on Rob's Micro Bassman LTP
Discussion in 'Shock Brother's DIY Amps' started by subgenius_one, Sep 25, 2020.
  1. subgenius_one
    subgenius_one TDPRI Member
    I am planning on starting a build of this in an old Alamo Fury 1x15 combo.
    I have a couple of questions as I am starting on purchasing the parts:
    1. Is there any place where that has the BOM of components handy to order (as opposed to manually adding each individual component to the cart)?
    2. I saw a suggestion to use metal film resistors, but an implication that carbon might be better for certain resistors. Does this really matter/can you hear the difference or does it just make some people feel better to have the vintage spec component? Is it fine to use all metal film?
    3. I see on the Cathodyne version that there is a headphone jack, but on the LTP it is labeled line out. Can this be converted to a headphone jack?
    Thanks in advance.
  2. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    I haven't seen this, folks get their parts from different places. You can automate some of this work by exporting the BOM from Rob's DIYLC layout, massaging a little in a spreadsheet then copy/paste the Mouser's BOM tool. It will get you out of the one-by-one shopping. I can elaborate a bit if you want to shop at Mouser.
    Without getting into the mojo-or-no-mojo thing, it's totally fine to use metal film everywhere. You might choose some metal oxide or ceramic parts for higher rated resistors, this will be based on ratings alone I reckon.
    Yeah you can apply either of those output jack configurations to either circuit. Mix and match!
    Paul-T and robrob like this.
  3. subgenius_one
    Thanks. I went ahead and added all of the components manually. Parts on the way.
    robrob and sds1 like this.
