BigDaddy23
I have a 2” PVC plumbing pipe with a glued cap on one end (to seal) and the same cap on the other but pressed on. I fill it with methylated spirits and soak dead round wounds in there. I tie a bit of fishing line through the string eyelets, pop them in with the fishing line over the end of the tube and push the cap on.
They are pretty much as bright sounding as new after a couple days and I’ve not had any fatigue/failures from this method. Bass strings are expensive here so anything to extend the bright sound mileage is useful. That said, I don’t do this with flats (no real need).
I’ve seen other folks de-tune a fair bit then pluck the string up and down between the nut and the bridge. The string hits the frets and the crap comes out of the string. I think the theory is it comes out easier without tension on it. I’ve tried that and it does work but not for as long as my soak method. It’s good if u don’t want to remove the strings from the bass or need to brighten it up in a pinch.
