A Cautionary Word On Body Shape Routing
Discussion in 'Tele Home Depot' started by Jack Wells, Apr 17, 2009.
  1. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    As many of you may have read in my posts I suggest downhill routing when routing a body shape to prevent tear-out. If you follow this suggestion, half the time you are not pushing against the rotating router bit cutter. It is therefore also suggested that you make several shallow passes and hold on tight to the body (when using a router table). If not the body could be pulled out of your hands.
  2. edd677
    edd677 Tele-Meister
    Ontario
    I admire the responsibility you feel when putting advice out there! Thanks for all the teachings
  3. e-merlin
    e-merlin Doctor of Teleocity
    Garden City, KS
    Well, that explains the UFOs out by Roswell.:D
  4. edd677
    edd677 Tele-Meister
    Ontario
    Ahahahahah :D
  5. irishtele
    irishtele Tele-Meister
    Ireland
    Any tips for routing out a neck?
  6. Jack Wells
    Albuquerque, USA
    Be very carefull routing the ends.
  7. Scatter Lee
    Scatter Lee Friend of Leo's
    follow the buzzards
    I like to clamp the wood down good and use the hand held router, hold on tight , seem to have more control
  8. Mr. B
    Mr. B Tele-Meister
    Canterbury - UK
    I also do my rounding over this way. Not so much scope for things to go drastically bad with the rounding over, but it certainly saves some time sanding things smooth.
  9. Leigh
    Leigh Tele-Meister
    Northamptonshire, UK
    Thats the way I did my thinline. And always shallow passes and downhill without fail.
