9-pin socket question
Discussion in 'Shock Brother's DIY Amps' started by islandjimmy, Oct 21, 2020.
  1. islandjimmy
    islandjimmy TDPRI Member
    Oregon
    Hi All,
    I am building my third 5E3 amp kit. The 9-pin sockets on my current build have a center post. I have not seen one of these before and I am not sure what the center post is for? It seems like it will get in the way when I wire across from pins 8 to 3. Anyone know what I should do with this extra center post?
    Thank you!
  2. elpico
    elpico Tele-Afflicted
    Vancouver BC
    It's just an extra terminal you can use to connect components to. It's completely optional, you don't have to use it if you don't want it.
    islandjimmy likes this.
  3. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    Ideally it is grounded but it doesn't matter much at audio frequencies - it would add just a bit of shielding between the two triodes in a dual triode tube. More important for radio frequency equipment.
    At audio frequencies it's just an extra terminal to do whatever you'd like. Or nip it off if it's in the way.
  4. islandjimmy
    Oregon
    Ah, I see. Thank you for the explanation. I will probably nip it off.
  5. tubegeek
    Brooklyn, NY
    I'm assuming you're not looking to add a Geiger counter or shortwave transmitter feature to your 5E3 this time? Although - it WOULD be pretty cool.
  6. tubegeek
    Brooklyn, NY
    There are tube sockets with like a Christmas tree of terminal points growing from that center spigot, so you can make circuits right on the socket, super-compact.
    The RF guys have all the really tricky stuff. This one is octal but you get the idea.
    ThermionicScott likes this.
  7. tubegeek
    Brooklyn, NY
    While googling I found this, from an IBM mainframe. Now THAT's a layout. 1024px-IBM_604_two_modules.jpg
  8. David Barnett
    David Barnett Doctor of Teleocity Ad Free Member
    So IBM used Mustard caps? Another good source for harvesting parts.
    tubegeek likes this.
