bchaffin72
My jar of dipping wax when all paraffin had significant sink/shrinkage after cooling. Adding beeswax in the 80/20 ratio I expected the shrinkage to change (too much shrink would cause voids and open up possible microphonic points) but it looks about the same amount of shrink.
Make sure to use a double boiler setup when melting your wax. A neighbor of mine when I was a kid burned his house down making candles.
Get an inexpensive sports ball pump, dismantle to flip over the check valve, and you have a vacuum pump or buy an automotive test vacuum pump but it will be 3-5 times the cost of the sports pump. Get an inline check valve from the fish department of a pet store to maintain the vacuum between vacuum draws on the converted pump, a large wide mouth (pickle) jar that you put a pipe mount through the lid. Connect it all with automotive tubing (to not collapse under heat) and put your wax in the jar that is in a larger pan of water. Put the pickups in the jar and draw the vacuum - you'll see bubbles exit the coil as the vacuum increases and wax goes in the coil. Lay the pickups on paper towels to cool.
Thanks.
