79 Vibro Champ issues.
Discussion in 'Amp Tech Center' started by jwp2, Feb 17, 2020.
  1. Whatizitman
    Whatizitman Friend of Leo's
    WV
    Yes it is soldered to the chassis. Or it should be. Look carefully at pin 2. The little bit of braided wire from pin 2 that leads to a gob of solder on the chassis right in front of the next tube (to the right of the 6V6, looking at the back side of the chassis). If it's not connected there (broken connection), then that's the problem.
  2. jwp2
    jwp2 Tele-Holic
    Chicago Ill
  3. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    Here is a shot of the 6v6 power tube socket. If I need to run a ground from pin to the chassis, I feel confident enough to do it.
  4. Ten Over
    Ten Over Tele-Holic
    Central California
    Holy Cow
  5. Whatizitman
    WV
    newrider1969 likes this.
  6. muchxs
    muchxs Doctor of Teleocity
    New England
    If you're putting your 6V6 in the socket with the two red and the two yellow wires... that's your problem.
  7. Whatizitman
    WV
    No, that is the rectifier socket. You will not need to add anything that wasn't there.
    jwp2 likes this.
  8. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    That’s the socket it’s always been in. Do I need to ground this socket at pin7?
  9. jwp2
    jwp2 Tele-Holic
    Chicago Ill
  10. muchxs
    New England
    5Y3 goes in the socket with the yellow and red cloth leads. 6V6 goes in the socket with the plastic insulated wire.
    Trust me on this.
    SnidelyWhiplash and jwp2 like this.
  11. Whatizitman
    WV
    No. Stop everything. That is the rectifier socket. The one closest to the power transformer. Do not put a 6V6 in that socket. Carefully turn everything off. Either take it to a tech, or do some reading up on amps before coming back to it.
    https://robrobinette.com/How_Amps_Work.htm
    SnidelyWhiplash likes this.
  12. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    I totally trust you this.
  13. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    Yeah, it’s tech time for sure.
    Guys, I really appreciate all your input.
  14. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    Actually I’ll try a 5Y3 before I take it to the amp tech. Thanks again for all the help.
  15. schmee
    If that's the case and the tube is not lighting up... you need to clean and tighten the tube socket.
    jwp2 likes this.
  16. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    Thanks Schmee, will do.
  17. jwp2
    jwp2 Tele-Holic
    Chicago Ill
    Hey guys, just a little update,
    I just installed a new rectifier tube in the Correct socket and she fire up and is working well again.
    I want to thank you all for taking the time out of your day to help me troubleshoot my little amp.
    You guys are the best!
  18. Marcusin
    Marcusin TDPRI Member
    Biloxi Ms
