Check out his post after yours. He had a pull boost on it and removed it and just replaced the Master volume pot. So both were correct. You are right about the 2 outputs and I didn't imply there wasn't but yeah don't know why I said one was 2 and the other 4ohm. Since in parallel you should not use another 2 ohm speaker as it would bring the impedance almost to a short at that point. But he wanted to know if the problem was stock speakers. Hence unplug the stock speakers and use the 8ohm one he had to test if he wants to eliminate the stock speakers as the problem.@Bluzzi - none of that is right about a Super Reverb. Master Volume had a pull boost on later amps, and there is only one speaker out, with an extension speaker in parallel.
@Jasonpatrick - schematic shows 500V on the CT- https://www.thetubestore.com/lib/th...er-Reverb-Ultralinear-1978-1981-Schematic.pdf - gotta get that extra wattage somewhere!
