73 twin silverface
Discussion in 'Shock Brother's DIY Amps' started by duffer426, Jul 19, 2019.
  1. duffer426
    duffer426 TDPRI Member
    In.
    have a silverface twin reverb, that when chopsticking the componets I notice when I tap the eyelet/fiberboard the tap can be heard through the speaker. Is this a ground issue? thanks
  2. corliss1
    Lansing, MI
    Probably not? Sometimes the boards themselves can become conductive, but it's much more likely you're moving a specific wire a bit, likely in the preamp. I'd try and tap each wire gently to see if you can reproduce it like that.
    D'tar and bblumentritt like this.
  3. D'tar
    D'tar Friend of Leo's
    WNY
    Cold joints can sound like a snap, crackle, pop;)(or any other arrangement of sounds). I had a Pro reverb that would produce noise through the speaker while tapping the board. Turned out to be a bad joint in the filter housing.
  4. robrob
    United States
    Probably a microphonic component such as a cap is being vibrated when you tap the board.
  5. schmee
    It's not uncommon at all. But can also be an indication of something going bad. Try pre tubes first. If a pre tube is microphonic (very common) it can make much of the board microphonic too when tapped.
    robrob likes this.
  6. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Just for fun really check out that resistor that sits inline with the length of the board. That one can get loose when the board warps.
    I'm voting on a bad connection.
    If you haven't already done all the electrolytics, now would be a good time.
