stratguy2015
Hey guys. This is a repeat post from last night. I didnt get many suggestions on how to fix this, so I'll try again on this larger thread.
I have a 73 Fender Bronco Silverface and the vibrato does not seem to want to oscillate. When I turn the intensity knob I get a change in voltage like I should but the circuit itself is not working. I'm going off of the AB764 schematic. I've changed the main can cap, the three caps in the vibrato circuit, a few resistors off of that. Still no vibrato. I checked the newly installed the caps in the vibro circuit, they are all good.
Here are some voltages:
Fender schematic AB764.
V1 VOLTAGES. MY VOLTAGES (V1)
PIN#1- 255V. PIN#1- 259V
PIN#3 - 1.9 V. PIN#3- 1.93V
PIN#6- 260V. PIN#6- 251V
PIN#8- 1.7V. PIN#8- 1.88
V2 VOLTAGES
FENDER. MY VOLTAGES (V2)
PIN#1- 210V. (FLUC) PIN#1- 133V(STEADY
PIN#3- 2V (FLUC) PIN#3- 2.87V(STEADY
PIN#6- 410 V. PIN#6- 414V
PIN#8- 216V (FLUC) PIN#8- 189V (STEADY
When I turn the intensity pot while I was checking the V2 voltages, there was a swing but the vibrato doesn't seem to be oscillating on its own. Have tried several different tubes. Where can I go from here? Any help is hugely appreciated!
V2 VOLTAGES
