72 telecaster deluxe with sanded matt finish
Discussion in 'Telecaster Discussion Forum' started by AJ Ray, Aug 1, 2020 at 3:46 AM.
  1. AJ Ray
    AJ Ray Tele-Meister
    dundee
    Have the chance to get one and the finish is putting me off slightly as someone has attempted to relic it by scratching it all with sandpaper then trying to sand the scratches out.
    Otherwise it is supposed to be a fine and playable guitar. Would have looked great in gloss black as well
  2. rangercaster
    Knoxville TN for now
    Without pictures we can't really tell ...
    Jus sayin ...
  3. Dacious
    Dacious Poster Extraordinaire
    Godzone
    If you liked it it would be possible to have it either wetsanded and buffed up or a shot coat over the top.
    I
  4. AJ Ray
    AJ Ray Tele-Meister
    dundee
  5. AJ Ray
    AJ Ray Tele-Meister
    dundee
  6. Dacious
    Godzone
    Take it to a smash repairer or furniture polisher literally 'that'll buff right out'
    You could get buffing compound and a buffer from your nearest auto store and do it yourself.
    Andre Rock and MrYeats like this.
  7. AJ Ray
    AJ Ray Tele-Meister
    dundee
    I think it's a poly finish. Still buffable?
    MrYeats likes this.
  8. Dacious
    Godzone
    Yep. You can do it by hand with lots of elbow grease.
    MrYeats likes this.
  9. Rhomco
    Rhomco Friend of Leo's Ad Free Member
    DFW, Texas
    Looks hand sanded. Use a good block to level wet sand. Be sure that you get ALL the old sanding scratches out or they will reappear after buffing.
    Good luck on your project,
    Rob
    MrYeats likes this.
  10. MrYeats
    MrYeats Tele-Meister
    Texas Coast
    Cotton buffing wheels on a drill motor work. there are different hardnesses of wheels from hard to soft, floppy ones...Not too much pressure at first, the hard ones will actually take off the paint...
  11. beachbreak
    beachbreak TDPRI Member
    Relic is good when caused by actual playing otherwise Im not a fan. Good luck with the restoration.
  12. Durtdog
    Durtdog Poster Extraordinaire
    Tennessee
  13. UPtele
    UPtele Tele-Meister
    MI
    I kinda like it, for the right price I would buy
  14. boris bubbanov
    New Orleans, LA + in the
    Yes. I mean, still restorable.
    With some samples, test various grades of sandpaper and determine what's the coarsest grain the "rusticator" used. Go to the next fineness to that and do the whole body, then the next fineness and so forth. The poly is thick enough you should be able to do a complete sanding of each fineness of paper until you see no scratches, through to 2000 fineness. THEN you can start with the polishing/buffing.
    Hopefully he used nothing coarser than 240. Otherwise, the process will be long, but it can be done and I think sanding through is only a concern IF the previous guy removed a lot of finish around the edges. Just don't pay too much; this vandalism should take $ 200 easy, off the normal going price.
