Twangisgood
Hi to you all.
I’ve got a deluxe reverb (the 68 reissue). It’s got an arcing power tube (I did swap them round to check that it was just the one tube)
Having had a look inside them, everything was fine except that just happened to notice that the screen grid resistors were reading different values to each other. Is this what’s caused the mismatch between the power tubes when trying to bias the amp (both tubes give different readings)
I’m not an amp expert at all, but have been enjoying leading a bit about this over the past few years. I’m in the uk and it seems to be hard to find the correct 470ohm resistors to replace these with? I might be wasting my time, but all I can think is that the mismatch of these resistors caused my nice Tung Sol power tubes to now be useless!
Like I said, I could be wrong but I’m worried about putting in a new set of tubes and running the amp if these resistor values are critical to be matched? If so, I’ll have to buy some, match them and replace them before I can use the amp again.
But if a mission! But hopefully someone might have a much better idea?
Many thanks
Many thanks
