I have got to a point with this project where I think I have most of the pieces in place.
The plan is to build a super-compact/portable “lunchbox” head based on Dave Hunter’s Two Stroke and the Weber Maggie amp for one 6L6 or EL34 in a 5F2a type circuit. Aim is to be simple, reasonably robust, and as short a signal path as possible. PtP wiring in compact Hammond 1550Z124 enclosure.
I have drawn out a schematic based on the titular amplifiers. I have omitted the boost switch as I would typically use a pedal to achieve that in actual use:
As I am using a solid-state rectifier, I have added an extra filter capacitor before the load resistor but I am not sure that it is necessary. I am also not sure about the values of each stage. For reference, the Ampmaker WF-55 is SS rectified and uses 20/20/20/20. Weber Maggie uses 20/8/8 or 20/16/8 depending on whether you look at the layout or the schematic. Two-stroke uses 40/16/8. I think I'd like to use a can cap for the power filter stages, and then put the preamp filter cap inside the box to separate the ground, but the multi-can cap values are limited.
Looking on Amplified Parts, CE have a 20/20/20 @525V
JJ have a 16/16 @500V and a 40/20/20/20 @500V
Obviously not all sections need to be used.
I am still reading Merlin's book and Jack Darr, but in the meantime, I am impatient to begin soldering...
Here's a gut shot of progress so far for interest's sake:
All comments and advice, as always, are gratefully received.
