6G2 Princeton build
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, Aug 5, 2021.
  1. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    So far so good.
  2. 2L man
    2L man Tele-Holic
    Finland
    Looks good but board lacks one inch of wire and obviously because of that there is going to flow current in chassis?
  3. Uncle Daddy
    Maldon, England
    It separates the filter grounds for the pre-amp and the power section, supposedly to reduce filter hum. The ground bar connects to the chassis via the input sockets, while the first two filter caps are grounded close to the transformer. Normally the 6G2 uses a can capacitor with a common ground for all 3 of the filter caps, and these are hard to source in the EU, so I built the board with a layout more like a 5e3.
    I've built a few amps this way, and they are always very quiet.
    Paul G., as5431 and Drew617 like this.
  4. Uncle Daddy
    Maldon, England
    Bias board done, bias pot in, PT wired up, rectifier diodes in, OT connected.
    as5431 likes this.
  5. Drew617
    Drew617 Tele-Holic Silver Supporter
    North Shore, Mass.
    Looks great!
  6. AAA71
    AAA71 Tele-Meister
    Ontario
    looks great - what buss wire do you use for ground? Havent seen it twisted before.
  7. Lowerleftcoast
    california
    Have you test fit the filter caps to make sure there is room between the board and the cabinet top? Those chubby ones don't fit well in this style chassis.;)
  8. Uncle Daddy
    Maldon, England
    I just checked, there's around 10mm of clearance. Good tip though.
    Lowerleftcoast likes this.
  9. Uncle Daddy
    Maldon, England
    Just regular push back solid core, stripped and doubled over and twisted slowly with a drill.
  10. RatBug
    RatBug Tele-Meister
    Arizona
    Watching this hoping it will get me excited to finally finish mine.
  11. RatBug
    RatBug Tele-Meister
    Arizona
    I did a whole twisted ground buss on my eyelet board build.
    SnidelyWhiplash and Drew617 like this.
  12. Drew617
    North Shore, Mass.
    Yep, have done all of mine that way, if I've used a bus at all. Twisting in a drill straightens it out automatically and keeps me from having to stock multiple gauges of buss wire. :)
  13. NTC
    NTC Tele-Holic
    Is this the only reason to twist the ground? There isn't an electrical reason to do this. It isn't like the heater wires where twisting helps to cancel the 60 Hz fields.
  14. Drew617
    North Shore, Mass.
    No, but take care not to twist it backwards or else the Thetans trapped inside will escape.
    Manageability, that’s all. Comes out perfectly straight, more gauge from less gauge, quite easy to solder to.
  15. Uncle Daddy
    Maldon, England
    A bit more progress.
    SnidelyWhiplash likes this.
  16. Uncle Daddy
    Maldon, England
    Coming on a bit-
    willholt92 and mk_716 like this.
  17. Uncle Daddy
    Maldon, England
    On the final leg now- PT and heaters hooked up, just the mains lead to do and then the fun begins.
    2L man likes this.
  18. Linkjr
    Linkjr Tele-Meister
    Uk
    Looking good inside and out, where did you get that great looking cab?
  19. Uncle Daddy
    Maldon, England
    The cab and chassis are from Mojotone, via an ebay seller that supplied the facep!ate and transformers. TBH, it's been an up hill build but it's coming together at last.
