6g2 in a vibrochamp 1x10 cab
Discussion in 'Shock Brother's DIY Amps' started by Wytee, Jan 23, 2021.
  1. Wytee
    Wytee TDPRI Member Silver Supporter
    South Dakota
    Thank you where i work we powder coat machines and 1 of our colors is traffic black which is a perfect satin black for these types of things.
  2. Wytee
    South Dakota
    Got little bit more wired tonight
  3. Wytee
    South Dakota
    99% wired. I hope to have done either tomorrow or Saturday.
  4. Wytee
    South Dakota
    The 662 is alive. I had a squeal which i just remedied by swapping blue and brown off the hammond 1750e OT. Here are some of the voltages
    1st node 325.7
    2nd node 319.4
    3rd node 298.2
    Plates 322
    Screens post 470 ohm 318.4
    v1 pin1 193
    Pin 6
    Havent had a chance to play through it as i just got going. I will assemble and post some more pics later. Then i will play some through it.
  5. Wytee
    South Dakota
    The bias pot i used 2 38k resistors in parralel and a 10k pot and I end up right in the middle of the pot range.
    Gunny likes this.
  6. Wytee
    South Dakota
    All voltages look good and amp is assembled. Heres a look
    Timmay, 2L man and Mexitele Blues like this.
  7. Wytee
    South Dakota
    Amp sounds good i do get the tremolo thump that I may address sometime.
  8. mjcyates
    mjcyates Tele-Meister
    Louisville, KY
    Wytee and Paul-T like this.
  9. Wytee
    South Dakota
    Thank you. I’ll try that. I had to order some caps. As soon as they come in ill open it up again.
  10. Wytee
    South Dakota
    How come you have .022uf on intensity pot? Normally its .047.
  11. mjcyates
    Louisville, KY
    Good catch. My actual build had .047. I just forgot to update the value in my layout. Probably from cut and paste.
    2L man likes this.
  12. Wytee
    South Dakota
    Looks nice
  13. mjcyates
    Louisville, KY
    Thanks! Its probably been my favorite amp build. Sounded very nice.
  14. schmee
    schmee Doctor of Teleocity
    Cool! I built a BF Princeton into my old Mono 15 cab and chassis. I just put the tranny's where they fit best. No noise. Tight fit.
  15. FenderLover
    Minnesota
    Where'd you get those?
  16. Wytee
    South Dakota
    Found on ebay
  17. Wytee
    South Dakota
    Went to a 12” speaker with oxblood cloth.
