6g2 in a vibrochamp 1x10 cab
Discussion in 'Shock Brother's DIY Amps' started by Wytee, Jan 23, 2021.
  1. Wytee
    Wytee TDPRI Member Silver Supporter
    South Dakota
    I had built a vibrochamp with a mather cabinet that was taller than stock with a 10”. I got the urge to do a 6g2. So i decided to make it fit the champ cab. I got a champ chassis that was an extra inch wide. Here are some pics of the layout so far.
    uriah1, NoTeleBob, gigante and 3 others like this.
  2. Wytee
    South Dakota
    I will have a 10k bias adjust that is not installed yet. I converted a laydown transformer to stand up in order to make more room inside the chassis. With this small chassis space is at a premium so ive been carefully trying to maximixe room.
  3. rdjones
    rdjones TDPRI Member
    Music City, TN
    Have you already done an induced hum test with that layout ?
    I suspect that there may be a quieter transformer orientation than what is shown.
  4. Wytee
    South Dakota
    No i have not
  5. Wytee
    South Dakota
    I stood it up so I could get the bias board to fit better. Probably should’ve laid it down. What is the preferred guideline for transformer mounting/ setup.
  6. FenderLover
    Minnesota
    I think you'll be fine the way it is. Your laminations are at 90 degrees and looks like good distance. I've built 40W blackface circuits with two 12AX7's in Champ chassis, and there is even a ODS out there in a standard Champ chassis. You already sources a larger chassis so just plan things accordingly and take your time.
    Junior Little likes this.
  7. Lowerleftcoast
    california
    I will preface this by saying... I really do not know if the *mark* on the Sozo cap denotes the outer foil side of the cap.
    That said, there are those who orient the caps to minimize noise. If the Sozo *mark* is the foil side, some would suggest to orient the Sozo the other way around on your board.
    I may be off base with the orientation *mark*. Maybe another shock brother with more experience with Sozo will comment.
    King Fan likes this.
  8. Wytee
    South Dakota
    I could spin the caps around. The yellow caps had a red line on them indicating foil. I wasn’t sure about the sozos. Thank you
  9. Wytee
    South Dakota
    Test fit in cabinet
  10. Wytee
    South Dakota
    Everything fits ok
  11. Willie Johnson
    Willie Johnson Tele-Holic
    Chicagoland
    Very cool! Little and grabbable like a Pro Jr.
  12. Wytee
    South Dakota
    I spun the sozos around too
  13. Wytee
    South Dakota
    Got front panel layed out today.
  14. gigante
    gigante Tele-Meister
    Kansas City
    Looking good. One day I'd like to build a 6G2. That's unfortunately all I have to contribute.
    wblynch likes this.
  15. Wytee
    South Dakota
    Probably gonna use these pot labels
    FenderLover, D_Hallett and James Knox like this.
  16. D_Hallett
    D_Hallett TDPRI Member
    Alberta, Canada
    Those pot labels look sharp - very nice!
  17. King Fan
    Salt Lake City
    FWIW, Sozo caps do mark the outer foil end with a line, so it's good you flipped 'em.
    Paul-T likes this.
  18. Wytee
    South Dakota
    Thank you. Heres front
    NoTeleBob likes this.
  19. Wytee
    South Dakota
    Got some wiring done
  20. jmp81sc
    jmp81sc Tele-Meister
    Orange County
    Great looking face plate.
