'69 Tele - replacement tuner recommendations
Discussion in 'Tele Home Depot' started by good.wood, Apr 1, 2020.
  1. good.wood
    good.wood NEW MEMBER!
    My '69 tuners have fallen apart (F-Style). I thought maybe the re-issue F-Style vintage ('70's) might fit, NOT. They are a tad bigger, the collar is bigger, screws not in same spot, so what do you guys recommend?
    I thought about selling this, but when you hold an old friend you just can't let'em go. I don't want to increase the tuner hole size because ultimately all that niggly stuff about being all original gets affected.
    When I bought this back in '84 from the guitarist in my band, he had put on Schallers, no screws into the headstock. I thought I would put the originals back in, but now understand why that was a fail, 2 of them are mega loose and fall apart. Do I just put those back on? Or is something that will fit, that is better you tele experts out there suggest?
    Thanks
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    These are oval button ones? I had a 78 with hexagonal buttons and a 69RI at the same time. I pulled them apart and every part interchanged. The only difference was the shaft was shorter on the new ones because the headstock was thinner. The parts were otherwise identical.
    .I think the earlier rounder button tuners may be different. If they have the spring clips on the chassis you can bend more tension into the clips to reduce endfloat.
    I haven't verified this, but it appears that sometime after 2005 Fender changed the source and newer MIM and Asian sourced F-tuners are Pings.
  3. Nick Fanis
    Athens-GREECE
    Unfortunately 67-74 F tuners are way different than post 74 ones.
    No current production "F" tuner can replace them so you are stuck with them.
    They are also horrible quality wise.
  4. nathanteal
    nathanteal Tele-Holic
    Rochester, NY
