68' Super Reverb question
Discussion in 'Shock Brother's DIY Amps' started by rpcruab, Feb 13, 2009.
  1. rpcruab
    rpcruab TDPRI Member
    Pennsylvania
    Sorry in advance for the dumb question. Should I bias when replacing tubes in my amp? I am replacing mine with a matched set of JJ's. Any advice appreciated! Thanks!
  2. Papa Joe
    Papa Joe Friend of Leo's
    Swanton Ohio
    YEP!!!!
  3. ThermionicScott
    CID
    If it's an unmodded AB568 circuit, it'll have a hum balance adjustment, so all you can do is adjust for least hum, not for an overall "hot" or "cold" bias.
    - Scott
  4. Tim Swartz
    Tim Swartz Friend of Leo's
    Michigan - Tweenst the Great Lakes
    Easily remedied by moving a couple wires.
  5. ThermionicScott
    CID
    Yep, that mod would be toward the top of my list. ;)
    - Scott
  6. rpcruab
    Pennsylvania
    It is an unmodded AB763 Circut.
  7. rpcruab
    Pennsylvania
    What should I search for to find this mod?
  8. ThermionicScott
    CID
    Perfect! Then you're fine. :cool:
    - Scott
  9. Tim Swartz
    If you are basing this statement on the tube chart then it may or may not be an AB763. They used the AB763 tube chart on Super Reverbs until well into 1969, you cannot trust them. Only very early 1968 examples are actually AB763 circuits. Black vertical line on the face plate is an indication of an early 1968 amp, however, the only way to know for sure is to open up the amp.
  10. Ben Harmless
    Ben Harmless Friend of Leo's
    Salem, Mass
    Obligatory "even unplugged amps can kill you, don't open them up if you aren't 100% sure you know what you're doing" statement here.
