SoK66
I used a jumper for R65 and left the 220uf slot open, no jumper needed. You do have to have the R65 jumper though or no current reaches the 47UF cap. Not sure if I mentioned above, while I was in there I replaced the cheezy 1 watt EQ and dropping resistors with 3 watt flameproof of the same value. Pic below:Did you replace this with a wire? Did you replace *R65 or eliminate it as well?
* R65 is on the filter cap board. It parallels the 220uF cap you removed.
