65 DRRI Conversion to Turretboard...
Discussion in 'Shock Brother's DIY Amps' started by tweedy_woodpecker, Nov 12, 2019.
  1. tweedy_woodpecker
    tweedy_woodpecker TDPRI Member
    Austria
    Just got finished converting a friends Deluxe Reverb Reissue...I'll check the wiring once more before firing it up tomorrow.
    Before (Note the two ugly PCB boards replacing the original Trem circuit).
    And after:
    JeffBlue, FenderLover, schmee and 3 others like this.
  2. EsquireBoy
    EsquireBoy Tele-Holic
    Paris, France
    Nice!
    I would not call the original PCB ugly though: it seems neat and quite well made.
    Your wiring is more vintage correct and easier to deal with for sure.
  3. Uncle Daddy
    Uncle Daddy Tele-Holic
    Maldon, England
    Did you make the turret board? I can only find eyelet boards online.
  4. twangjeff
    twangjeff Tele-Afflicted
    Houston, TX
    With that green circuit board, I thought the first picture may have been the new Tonemaster Deluxe Reverb... ;)
  5. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    That was a lot of work. Impressive!
  6. tweedy_woodpecker
    Austria
    Thanks guys!
    Happy to report the operation worked and the patient is well.
    Yeah, the PCB ist not ugly, but I am glad that the hum and noise issues in the reverb and tremolo section are gone now and the tremolo finally sounds like it should
  7. schmee
    schmee Poster Extraordinaire
    I did one years ago. It worked out fine. I reused the pots in the amp. Just had to solder to the little PCB tabs on the pots. But that worked great and those pots are smooth and nice. Did you install new pots or reuse? I happened to have an old Fender AB763 eyelet board around and used that.
  8. tweedy_woodpecker
    Austria
    I installed some new pots, I did not want to bother unsoldering the old ones, also thought it looks more authentic this way
    It was a ton of work, yes I did my own turretboard and figuring out the connections from the transformer and doghouse (different colour coding) took a while.
  9. Frankie
    Frankie Tele-Holic Silver Supporter
    Fostoria, Ohio
    Very cool.. Awesome job!
    tweedy_woodpecker likes this.
