Menuiserie
Hello,
I had a Deluxe reverb reissue for quite a long time, not using it much because it was a bit noisy. A mix of hiss, 50Hz and harmonics.
Changed tubes, nothing helped.
Last month I decided to recap it thinking it might be caps leaking.
No it was not. So I tried twist the AC wires, and added a humdinger balance pot for heaters. As per some advices, 6.3V is now soldered directly to tubes, and heater balance resistors are connected to humdinger, with wiper connected to V8 cathode (ground).
I could remove some of the hum, but not enough.
As I had ROHS tremolo circuit, I bought a Fender optoisolator and reverted it to the regular circuit (removing both added PCB and 7 10k grid resistors that were on the preamp grids, near the sockets.
No more hiss from the tremolo intensity volume, but still general hum and hiss.
Then I removed some of the tubes to isolate the problem.
With only PI and output tubes + rectifier : no hum, no noise, very very clean.
I add V1. I get the normal channel. It is clean, no problem, a bit of hiss when I crank the volume but nothing unusual, beautiful sound, no hum.
I add V2. No noise. The weird thing is I can get the vibrato channel (without vibrato and reverb of course) working, but with low level, and no treble, but still no hum. Looking at the schematic it should be muted as it passes through V4 (absent), isn't it?
I add V3, V5, nothing changes.
I add V4. Hum, hiss. When I crank the reverb button, a lot more of them (tank not attached). As I understand it, V4a is the reverb return driver and V4b is the fixed gain 3rd preamp stage of the second channel. So If V4 is wrong, this should affect both these fonctions.
I tried changing tube. not the solution.
I tried poking with a chopstick, reverb return up : every V4 wire but the heaters are microphonics, also every direct connexion with them (rca hot rev return, R28, etc). I reflowed those connexions. Checked good with DMM, but nothing changed when powered. Still Hum and microphonics wires, even when I change for a known good tube.
Checked again those new filter caps, they are good on the mesure.
I'm running out of ideas here...
What do you think?
Thanks a lot for your answers.
What do you think?
