'64 Vox AC30
Discussion in 'Amp Tech Center' started by corliss1, Oct 21, 2020.
  1. corliss1
    Lansing, MI
    Fiiiiiiiiiine :D
    The front - some serious mojo
    Back - also serious mojo
    So British
    Someone thought they had a good idea back in the day...
    Do...do I see this actually had a service done? That can't be right........(notice extra tube for the tob boost circuit inside the amp there)
    Numbers
    Has the correct multi-tap PT:
    So if you've never ripped apart a Vox before, the first thing you have to do is unscrew the speaker wires from this little terminal board.
    After that, you'll quickly realize that nothing is holding these amps together. They sit on a piece of plywood that is attached to.............nothing. It sits in rails on each side and just holds the chassis up. Here we can see it starting to slide out.
    Back with original speakers:
  2. corliss1
    Lansing, MI
    The customer complaint - "Just got it today. Had it shipped. Hums, and isn't very loud."
    Well, that doesn't sound like an AC30. We'll make it loud, and teach it some words so it doesn't hum anymore. (not even sorry about that joke)
    Speaker close up:
    First sign this could get interesting - looks like some shipping damage. Remember how I said that plywood isn't attached? What most likely happened is that the plywood slammed into the back panel, and popped this nut insert loose, breaking away some wood in the process. No big deal - we'll epoxy it in later on when I get to that point.
    Only logo left on it:
    Guts removed:
    More evidence of actually being serviced:
    Let's flip it over and get that plywood off to see the guts. That middle screw is also holding on the top boost board bracket.
    More servicing. It's not the prettiest solder work, but it's all solid.
    Man, these resistors look cooked (file this away for later...)
    More cooked evidence:
  3. ThermionicScott
    CID
    Too cool, subscribed. :cool:
    corliss1 likes this.
  4. corliss1
    Lansing, MI
    Alright, so it's serviced pretty recently and doesn't need a cap job. Let's fire it up and see what happens. We'll grab a scrap piece of wire and hook it up to that terminal block so we can connect some speakers:
    And then we'll plug it in........oh, no we won't. It's still British...
    Made it more American, then we plug it in, and we get this:
    That's certainly not ideal. Half the power supply is redplating and that would definitely cause quiet and hum. And certainly could cause those cooked resistors.
    So...where do those connections go. Oh, to this broken wire that feeds half the power supply:
    So here's what happened. The previous service, which also included a replaced tube socket, seemed to shorten that wire. The wire was so tight it was pulling on the board, and broke. I couldn't reuse the old wire since it was so short, and even shorter after breaking, so I replaced the wire. That allowed the amp to actually function, but those super cooked resistors needed to go too. There were also 50% off spec.
    Clean that hole:
    New wire that actually wraps around the hole:
    Shiny new 1.5K resistors. Reused the original spaghetti except on one that was torn:
    So cooked:
    Nice pretty solder now:
    So that's where we're at. Gonna talk to the customer, probably recommend new tubes since I'm guessing those cooked like that for a while (and you can see the one side is burned more for sure) and then it'll be back to its home!
    As usual, these amps sound fantastic. Has all the "chime" and other Vox-y buzzwords attributed to this model. The trem is fun, footswitch is there and works.
    JamesAM, Piotr, Jon Snell and 2 others like this.
  5. CV Jee Beez
    CV Jee Beez Tele-Holic
    Duarte, CA
    Looks similar to my old '64. It was a copper panel with integrated top boost. Always good to see the Wima caps.
  6. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    @corliss1 nice guts! How much of the vintage value did you destroy by replacing the magic mojo original wire, d'ya s'pose?
  7. Mr. Lumbergh
    Initech, Inc.
    Noice. Sweet amp.
    My favorite sound in the world is a Tele or Gretsch running through a splitter into a Twin and an AC.
    Wulf and corliss1 like this.
  8. tubegeek
    Brooklyn, NY
    They're little windows! Into a 4th dimension!
  9. elpico
    elpico Tele-Afflicted
    Vancouver BC
    Wima still make excellent caps. I don't see them around here, probably because they're all radial format these days, but they're quite popular in other areas of the audio electronics world. Nelson Pass uses them a lot in his builds for example.
    CV Jee Beez likes this.
