'63 VVRI Ground Switch Removal help:
Discussion in 'Amp Tech Center' started by brokenbones, Nov 4, 2016.
  1. brokenbones
    brokenbones Tele-Meister
    Indy
    I'm wanting to remove the "non-functional" ground switch to install a bias pot. The switch has 3 speaker wire connectors running to the PCB board. On the PCB there are traces leading to other components. Is it okay to just remove the wires and leave the leads that are soldered into the PCB? Would that cause ground hum?
  2. Wally
  3. tele_player
    tele_player Tele-Meister
    Sacramento, CA
  4. Wally
    Correct. The schematic shows a functional switch. That shows what connections must be maintained in order to bypass that switch. Transferring that information to the PCB tells one what should be done.
    As I often am, I am back to the old 'here's a fish' versus 'here's how to fish' thing.
    Luthier Vandros likes this.
  5. tele_player
    Sacramento, CA
    Deleted
  6. Wally
    MY apologies....that revised schematic does NOT show the original drawing. I have always found these things to be 'understandable' when they are sitting in front of me. I think anyone who is going off into such a situation should be able to examine, consider and decide what needs to be done there. Like I said.....get a fish for free without any work/learning or learn to fish...Confucious said it a long time ago.
    Here is the original and unbutchered schematic....fwiw....
  7. jazzguitar
    jazzguitar Tele-Afflicted
    Germany
    Does the ground switch have a center position ? (from the silverface years onwards mostly a ground with center position was used)
    If so, why bother about it ? Put it in center position (takes it out of the circuit) and forget!
  8. robrob
    United States
    That switch does not look non-functional to me. I'd leave it be.
  9. brokenbones
    Indy
    I decided to put the entire project on hold for now. PCB work is not something i'm comfortable with just yet. Until I find something definitive on the switch i'm not going to touch it.
  10. Wally
    Fender did not use that switch on the Custom Vibrolux Reverb, which uses the same PCB and chassis as does that '63 VVRI. It is a polarity switch. It can be removed. One need only understand how to 'bypass' it. That entails seeing the incoming ACleads contact points and the contact points for the two PT primary wires. If one is not confident in figuring that out, it is best left alone.
    The CVR has that chassis hole underneath the back panel, and it makes for a convenient spot in which to place an adjustment pot for the bias circuit.
    I also apologize for not giving the link to that unaltered schematic that is available online. I'll post that in a while.
