62 Strat
Discussion in 'Stratocaster Discussion Forum' started by Phil Coggan, May 18, 2020.
  1. Phil Coggan
    Phil Coggan TDPRI Member
    South Wales
    I bought this 62 Strat a few years ago, it was unplayable as the neck was twisted and bowed, there was a new 5 way switch fitted, the original was in the case broken in half. It's been re-sprayed at some time, previous coats show light blue, but I think it was sunburst originally.
    Here's some pictures showing the repaired switch and the neck correction.
  2. Nick-O
    Nick-O TDPRI Member
    SC
    Lovely...a month younger than me!
  3. Stubee
    Stubee Doctor of Teleocity Gold Supporter
    Mid-Michigan
    Nice to get her playing again!
  4. tah1962
    tah1962 Friend of Leo's
    Heart of Illinois
    Very nice!!
  5. RoscoeElegante
    RoscoeElegante Friend of Leo's
    TooFarFromCanada
    Nice work, mate!
  6. 68tele
    68tele Friend of Leo's Silver Supporter
    East Northport NY
    How long did it take to 'untwist' the neck?
  7. Fretting out
    Fretting out Friend of Leo's
    Land of Mary
    I like this guy! I can’t wait to see what’s next
    Woe! I don’t know if I’ve ever seen a truss rod nut sunk that deep
    I wonder if the red paint has anything to do with Hank?
    There was an article I read once where they interviewed a guy that sprayed the bodies from sunburst to fiesta red when they arrived in England, I think he may have sprayed them for Selmers and maybe another dealer as well
    whoanelly15 likes this.
  8. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    Weird neck stamp. Looks possibly touched up. Maybe this is being accentuated a bit because the photo is out of focus.
    A slab board at that point in 1962 is strange. If original, it was sitting around for a while before being stamped.
    Unionjack515 likes this.
  9. monkeybanana
    monkeybanana Tele-Meister
    mmhmm
    Impressive. I feel like most people would have chucked that switch too.
  10. guitarmikey
    guitarmikey Tele-Afflicted
    Bucharest
    Great job, incredible guitar! Looong for one...
    What results with the neck? I have a bass with a bowed neck, tried to keep it under pressure for some days, but no result. Ironing helps? Can you tell me a little more about...
    Thank you...
  11. Phil Coggan
    South Wales
    It took about an hour to set up, then heat applied for another hour then left over night.
    The neck stamp is original, the truss nut was pulled right in, so packing had to be used to bring it out so that the neck could be adjusted.
    The heat adjustment principle is this. The neck has to be clamped straight, the twist was pulled out with the guitar strings, so when the tuners are adjusted, tension pulls the neck to the correct position, the heat softens the fretboard glue, when it cools it locks the neck in the clamped position.
    68tele and Bikersluggo like this.
  12. Phil Coggan
    South Wales
    Here's what it sounds like with an old Shadows tune Kon-Tiki, recorded as close as possible to the original, 62 Strat > TVS3 > VOXAC30H2 and through an Altec 436c, Fender Jazz Bass, Taylor acoustic and BFD2 Drums.
    https://app.box.com/s/z4sf2zehlxxih2q7p8ycm0va06jmyp5b
  13. Lonn
    Lonn Friend of Leo's
    Indiana
    Nice! 3 weeks younger than I.
  14. fenderrookie
    fenderrookie A fan of Leo! Ad Free Member
    Denver...................IN
    A stunning example..... nice save with the neck.
    What was used on the switch, 2-part epoxy?
  15. Unionjack515
    Unionjack515 Tele-Afflicted
    Batavia, IL
    I’ve never heard of a September ‘62 slab board—they were using veneer as early as June or July—but I suppose anything is possible! Either way, nice work saving it.
  16. Mid Life Crisis
    Mid Life Crisis Poster Extraordinaire
    Cambridge, England
    Wow, great restoration. Really nails the Hank sound on that recording too!
  17. Phil Coggan
    South Wales
    No hard and fast rules with Strats, this covers nearly everything, after July 62 a "curved fretboard was used, ie convexed, to replace the slab, but there were lots of things done at the factory which were not documented, older stock necks were probably used...who knows?
