'60s Jazz "stack knob" plate same size as 3-knob version?
Discussion in 'The BASS Place' started by milocj, Nov 25, 2016.
  1. milocj
    milocj Friend of Leo's
    Michigan
    Not sure if this forum has enough gearheads to know the answer or not. I'm putting together a partscaster Jazz Bass for a buddy and am wondering if the routing and mounting holes are the same for the vintage stack knob versions as they are for the later 3-knob.
    I already have a plate and plenty of pots for the later versions, but if the stack knob plate is a direct replacement I may try grabbing one of those and wiring that up first since he's played an original and liked that set-up a bit more. If the plate isn't a drop in for the standard version (which this body has already had installed in the past) its not worth the cost of the stacked pots and knobs to give it a try.
    Thanks.
  2. erratick
    erratick Tele-Holic
    SoCal
    Same if you are using American Fender type parts. Some of the Squiers have little tiny pots.
  3. milocj
    Michigan
    Thanks.
    Not using a Squier body so I can try the '60s wiring.
  4. TELE_BLUES
    TELE_BLUES Tele-Afflicted
    ROCKCHESTER,NEW YORK
    Here's a pic of a friends original (strings also) stack knob jazz.He has me in his will to get it if he goes 1st. IMG_2500.JPG
    erratick likes this.
  5. Cadfael
    Cadfael Tele-Meister
    Dortmund, Germany
    Same dimensions ...
    Leo would never have replaced a pickguard or a body (or changed the rooting) just because of new electronics ... ;)
    TELE_BLUES likes this.
