60's Classic Tele tuners ( Mexico)
Discussion in 'Telecaster Discussion Forum' started by Nogbad, Oct 19, 2020.
  1. Nogbad
    Nogbad Tele-Holic
    Washington UK
    Hi,I need to replace my tuners in my 2007 mex 60's classic. Can some one please point me in the right directions for the right size ect. ? Much appreciate any help.
  2. Fretting out
    Land of Mary
    I know kluson brand vintage style are a direct replacement, I’m not sure about gotoh or Grover
  3. Nogbad
    Nogbad Tele-Holic
    Washington UK
    Ill Check them out. Should be an upgrade yes?
  4. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Gotoh are a pretty reliable choice, should be an easy install.
    Should be similar quality, I've never had any problem with those Mexican tuners.
    What's wrong with the ones you have, why do they need replacing?
  5. netgear69
    netgear69 Tele-Afflicted
    england
    Measure the inside of the bushing find tuners with the same shaft size and leave the bushings in
  6. Nogbad
    Nogbad Tele-Holic
    Washington UK
    I used to use wall hangers until one new year......E1 is bent and inaccurate!
  7. kinkstah
    kinkstah Tele-Afflicted
    Brittany
    Gotoh vintage style tuners would be my choice, too. As far as I know, they should be a direct swap with the Pings that came on the MIM Classic Series.
    Greggorios likes this.
  8. Nogbad
    Nogbad Tele-Holic
    Washington UK
    Cheers guys. Watching Dan and Mick live now.
    stressdoubt likes this.
  9. jfgesquire
    jfgesquire Tele-Afflicted
    Lake View
    Kluson vintage tuners are 1/4 inch, not 6mm. .25 inches is like .63mm and the Kluson posts will NOT fit in the existing bushings/ferrules.
    telemnemonics likes this.
  10. BobTheOwl
    BobTheOwl Tele-Meister
    Sheffield UK
    I’ve swapped mine for Gotoh. You will need to change the bushings.
  11. Boreas
    Boreas Tele-Afflicted Silver Supporter
    Adirondack Coast, NY
    Fender Vintage Tuners won't fit? Split-shaft tuners are always my choice on a Fender.
  12. AJBaker
    Switzerland
    Maybe you can bend it back? Happened to me once when I had my strat on my back in a gig bag and I tumbled over a bench in the dark. The e tuner was just about touching the b tuner, but I was able to bend it back and it hasn't caused me any trouble since.
    Boreas likes this.
  13. telemnemonics
    I put MIJ Gotoh split shafts on an MIM vintage style and there's a little more gap between the tuners so they can go a little crooked.
    IIRC anyhow, might have been used pings but the point being that you can get identical looking vintage style split shafts that are just a little off. As already mentioned above.
  14. heffus
    heffus Tele-Holic
    cHICAGO
    Get some Gotoh SD91 tuners and Gotoh 9.2mm Fender conversion bushings. I've done it to
    three Classic series necks.
  15. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
