6-Way Switch Review!
eallen
EDIT/UPDATE!
I mistakenly posted the NON-WORKING diagram in the original post. I updated it to the correct diagram. Deaf Eddy also indicated the jumper from 0 to 7 on the drawing is not needed. Here it is again & my apologies!
Eric
wabashslim
Sonorous Desert
I agree also! I don't like 4 or 5 way switches. A 6-way blade would hurt my head. In the heat of a gig I want the switch to go back - middle - front and nothing harder to find than that. (For the same reason I just want master volume & tone.)
My 3-pickup guitar (Shergold Masquerader, which has a Tele bridge & Strat middle and neck pickups) came with a 5 way switch and I rewired it to have a 3 way traditional Strat switch (one pickup per position) and a push-pull tone pot to swap over to the 3 2-pickup combos (B+N, B+M, M+N).
Guys like you must have a helluva time operating a toaster oven.
AAT65
West Lothian, Scotland
Well I don't even know what a toaster oven is, but if it's kitchen equipment I don't think you'd need to change the settings between one beat and the next while the stage lights are getting in your eyes...
R. Stratenstein
Loganville, Ga.
I just finished this monstrosity for a good friend as an experiment and what a nightmare to wire. I doubled up two J bass pickups and made them into humbuckers. The 2 volumes are push/pull and one is for coil splitting and the other is master series/parallel. Plus it has a pickup switch. My buddy says the different tones are infinite and all sound great but he's already picked out only a few. Personally I just don't see the need but I'm a traditionalist when it comes to guitars.
I wouldn’t call that a monstrosity!
solfege
Philly
Yeah I went through a bit of craziness trying to figure out what to do with one of these on a Strat I was putting together. I might still rewire it again, but I've got it working and I enjoy it. But I happened to use an old school Strat pickguard with countersunk screws and that probably made things work a bit better from the POV of switch travel. Had to expand the notch pretty much almost to the screw holes on both ends in any event.
R. Stratenstein
Loganville, Ga.
Damn good to see ya boy! :cool::D
Howdy, Dave, great to see you’re still building!
Rick! Nice to see you here!. I call it a monstrosity because I was seriously jinxed with that build. Everything went wrong. From refinishing to the wiring.
Ahh, now it’s clear, I’ve had a few like that meself. Glad to see you on the ole forum, also.
