When a recipient of a Nashville I was building asked for a 6-way switch I did my usual, why not! I thought I would sharemy experience should anyone else pursue using one.
I had read a bit in the past about the Oak Grigsby 6-way & info seemed readily available. The owner asked for a series position to be included like a on a standard 4-way. I lazily found a series diagram so I wouldn't have to bother coming up with one. Soldered it up and...1st 3 positions were very unlively bridge only & the rest nothing special.
Now I'm no wiring guru but when I started trying to sort out the switch with the diagram it didnt add up. Thanks to the gracious assistance of @Deaf Eddie he was able to sort it out for me with the diagram below.
To shed a little light. There appear to be a couple maps of the switch contacts out there and the incorrect one results in a faulty diagram.
On to the review.
Good: With the right map the switch functions the way it should with 6 great tone variations.
Bad: the switch has a significantly longer throw than even the 4 & 5 way OG switches. I mean ridiculously longer requiring the switch slot to be enlarged by
.22"!
The throw is so long that the switch won't fully seat in the 1 & 6 position using a typical tele switch tip unless perhaps you find switch mounting screws with much smaller heads or endeavour to countersink the switch plate and use flush head. You can see how much further it had to travel when the tip was pulled up enough to clear the screw head. Strat switch tips will get by but are still tight on getting fully seated. Since I build as many rear cavity guitars I am not sure the longer throw would even be possible extending thru the thicker mounting surface of wood, certainly only with flush mounting screws.
Verdict: The poorly thought out switch slot issue that isn't worth the hassle IMHO.
Eric
On to the review.
.22"!
Eric
