6 in line vs 3 on a side vs straight/tilt
Discussion in 'Tele Home Depot' started by pypa, Oct 20, 2020.
  1. pypa
    pypa Tele-Meister Ad Free Member
    new jersey
    I can only find design examples of 6-in-line tuners with straight headstocks, and 3-on-a-side with angled headstocks.
    I understand why 3-on-a-sides might normally need the tilt (to possibly compensate for out-of-line strings to the tuners.
    But why aren't 6-in-lines ever tilted, to eliminate the need for staggered posts or trees?
    crazydave911 likes this.
  2. crazydave911
    East Tennessee
    There are plenty, just not named Fender or Gibson :)
    ramonet and ctmullins like this.
  3. Freeman Keller
    Six in a line dates back to Stauffer and before
    Obviously they can also be one side of a twelve string or lots of other configurations
    Jim_in_PA and crazydave911 like this.
  4. schmee
    schmee Doctor of Teleocity
    I would say because of cost, tilted headstock takes more manufacturing time and wood?
    AAT65 likes this.
  5. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    Plenty of inline 6 / tilted headstocks on shredder guitars, Jackson, ESP, et. al.
    Never seen a flat 3&3 though.
    Edit: Do Porsches count?
  6. crazydave911
    East Tennessee
    The original Snakehead Tele was :)
  7. Freeman Keller
    Angled heads are traditional, whether slotted or solid, and allow control of the string breaking over the nut. You simply have to have some way to hold it in the slot. I think Leo started using the flat head simply for cost - once jigged up it is simple to make. The string tee ("tree") solved the break over problem and the look became iconic.
    The one big advantage that straight heads have (and I'm sure this was not the reason Leo used them) is that they are much less prone to breakage. Angled heads with short cross grain break.
    AAT65 and crazydave911 like this.
  8. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    1966-Gibson-Trini-Lopez-Pelham-Blue-1.jpg Gibson Trini Lopez. The exception to many rules. This is the Standard, the deluxe model also had this feature.
    The Firebird also.
    TwangerWannabe and crazydave911 like this.
  9. Freeman Keller
    I had a Trini on my work bench a long time ago, along with a rather nice vintage 335. In my opinion the Trini just looked weird.
    crazydave911 and tubegeek like this.
  10. telemnemonics
    All four specs mix & match, we just see trad Fender and trad Gibson as the center of the universe.
    crazydave911 and ctmullins like this.
  11. schmee
    For sure on the breakage thing!
  12. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Framus made lots of flat 3x3s, and they included a string bar to keep the break angle over the nut sharp enough so the strings ring properly. But then that bar created the expected tuning stability issues.
    On some of these, the headstock develops a forward bow. It's just a matter of time before it turns into a fist like you see on upright basses :twisted:
    It wasn't just 3x3s, either.
    Here's a particularly scary one:
  13. Freeman Keller
    Yeah, but thats really only an issue with sawn heads. Joined head can be strong enough to not break and are so much more efficient at their use of wood.
  14. AAT65
    AAT65 Friend of Leo's
    West Lothian, Scotland
    Two 3x3 headstocks with different approaches: on the left is my Shergold Masquerader, with a flat headstock (set back no more than a Fender) using variable height locking tuners to get the break angle needed over the nut. On the right is my PRS SE245 taking a more traditional approach with a back-angled headstock.
    BTW both are designed to have a straight pull through the nut to the tuners — it’s not particularly difficult to do on a 3x3 headstock, Gibson have just decided they’re not interested!
    crazydave911 and EsquireBoy like this.
  15. David Barnett
    tubegeek likes this.
  16. David Barnett
    SD Curlee guitars and basses had 3 on a side (or 2 on a side) headstocks with no tiltback.
  17. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    crazydave911 and JJLC like this.
  18. TwangerWannabe
    TwangerWannabe Tele-Holic
    West Coast
    Don't know, don't care.
    Some look this way, some look that way. They all work.
    Play more, think less!
    I_build_my_own, crazydave911 and JJLC like this.
  19. DavidV
    DavidV Tele-Meister
    Springfield, MO
    https://www.tdpri.com/threads/a-semi-hollow-thing.1050086/page-2
    I tried an angled 6 on a side headstock on my recent build. The end of page 2 has pictures with some finish on it. I mostly made it this way to avoid using strings trees, and I just think it looks good.
    It seems like a pretty strong joint but I could see where the added length makes it more prone to breaking.
