GlenroseMedia
First Build- “moderately modded” 5F6A, built in a Hot Rod Deluxe chassis, using HRD transformers. Added a 5v secondary transformer for 5AR4, wanting tube rectifier “sag”. Stock HRD transformer has no center tap for HV- so added a half bridge for ground reference. Then decided to full bridge before the 5AR4 for protection- ala robrob. Now the question:
Followed startup guide from Rob’s website, grounds etc. powered up with no tubes through variac and dim bulb (75w)- all voltages in spec. When I added the 5AR4 and did slow burn-in 10v steps through the variac, I got to 60v AC and the bulb started to glow, almost full brightness, then backed off some, but was limiting the voltage at about 55-60v AC, regardless of variac setting .
I removed variac from circuit, and about 20 seconds after power on, dim bulb did same thing; 5AR4 gets pretty hot, but no apparent glow. Also appeared not to be getting DC voltage correctly after the tube- even though the bridge diodes should have been providing.
Should an assume bad Rec tube? Is there a way to test? I can take the tube out of the power supply circuit, and just use the bridge to continue testing, but want to make sure there isn’t anything else less than obvious I should be seeing.
Sorry for long winded post- and thanks in advance for any advice!
JP
JP
