5E34EVR
Hello, first post here by an occasional lurker. I finally registered to give thanks to all that have come before for the wealth of info I have found here.
And... I am seeking some input that I have not been able to find answers for, either here or with Uncle Doug, RobRob or Lyle @ Psionic.
I am about to get into my 5th amp build based on the 5F6-A Bassman circuit.
My first amp was a 5E3 kit from Boothill (thanks Dave... good starter kit - I went back over this recently and upgraded the tube sockets, added a master volume and 3 way NFB switch... then gifted it to a friend).
Then I built another 5E3 from scratch using Jupiter Cosmos for filtering and Sozos for coupling... and did several of RobRob's suggested mods. (thanks Rob! - your work and generous sharing have really elevated my understanding of amp circuits)
I also built a Ruby in a pedal enclosure - just to keep busy while I planned my next tube build...
The last one I built was a customized Princeton for a gigging player I met when I sold him an old Peavey combo. I let him play my Modded Deluxe, and he was blown away - convinced me to build him a 20+ watt Princeton... (getting enough clean headroom was a real challenge with that cathodyne phase inverter)
I had built a beautiful highly figured black walnut head cabinet with a flame maple front that I had planned to do a Trainwreck Express build... but now will use that for this Bassman. So... I am looking for some input on the following:
1. Speaker cabinet - Is there a certain magic to having 4 x 10? Would a 1 x 15 lose some of that mojo? What about a 2 x 12? Alnico of ceramic? (the 12" Allesandro 1964 I used in the Princeton is probably the nicest speaker my ears have heard) If 4, what wattage and wiring would be best from a single output jack (1750JA, so I have 4 and 8 Ohm secondaries to chose from)
2. Favourite coupling caps for a bassman? - I have a surplus of CDE Orange Drops on hand... I used Mallory 150's in the Princeton and Sozo's for the Deluxe... all sound good to my ear. But in a Bassman, what is your preference?
3. I like using Hammond iron as they are easy to get and nicely priced here in Canadastan... I have a 1750JA for the OT and a 194A Choke on hand... is a 4H choke enough? which PT would you go with? 290DX or 290D2X... I will run a GZ34 Rectifier, but also going to have a switchable diode rectifier mod, my wall voltage is a perfect 120VAC. I am going to build for 5881 tubes, but want to try 6L6GC's as well with a rebias (yep, putting in an adjustable bias pot too)
4. I did an adjustable slope resistor in the Princeton and was thinking of replacing the 56K slope in the bassman as well... would you do this? Although a different approach than the presence control, the net effect on the sound is similar... would having both be a waste of effort or maybe have a negative effect on each other?
5. Summary of mods... NFB switch, Adjustable Bias, Rectifier Switch, Rob's Lead Channel mod, adjustable slope, and... a master volume...
6. that's a lot to pack into a 14" x 6" chassis... so will need to carefully plan grounding and lead dress. Has anyone ever done a mod to use a single volume control for the 2 channels - a single 1M pot after the 270K mixing resistors?
7. Trying to decide whether to use Carbon Comp throughout or Metal Film with just the V2A 100K Plate load and V2B 100K cathode resistors carbon comp.. dropping resistors will be wire wound... I have a good supply of 3 watt metal film in all values needed.
8. Presence pot... original schematic shows 5K Lin, but I have seen 25K as well with a 4.7K resistor... thoughts on best configuration for the presence? My understanding is that the 25K and resistor will remove the crackle when adjusting... but is there something lost in the tone?
Thanks All!
Thanks All!
