Thank you sir for taking the time to explain a little bit about how to use this amazing tool. Once again I am going to try to wrap my head around it.![]()
Universal Loadline Calculator
This calculator allows you to trace the anode characteristics graph, and to compute and tune loadline and operating point of various vacuum tubes.www.vtadiy.com
There is a 6SL7 model in the simulator. The "Quiescent Operating Point:" has the mA that is going through the tube and the voltage the plate is sitting at. The "V+" is your supply voltage "Load (Ohm): Resistive" is the plate resistor and "Next stage AC Impedance (Ohm):" is the next stage grid leak resistor or a volume control.
With a 250V supply, a Load of 100k, and entering 1mA it gives a grid bias of -1.4V. It is not quite center biased, that would be a little colder. With 0.8mA it is more centered biased (if that was the goal, it may not be for you) and the plate voltage ends up at 170V. You can adjust the mA and the grid voltage by adjusting the cathode resistor. In this case, 1.9V / 0.8mA = 2,375 ohms. A 2.2k will get you there. Adjusting the cathode resistor and plate resistor will move things around for you. You could add the next stage load, say a 1M pot, it changes the AC load line a little, without it you get the dc load line.
You can figure out the gain by reading off the chart, "Out. headroom (+/-V):" is something you can input. 100V looks a little too wide for the above, 80V seems to work. With the bias at -1.9V and the output voltage of 80V we have, 80V / 1.9V = a gain of 42.
It also gives harmonic distortion, in this case with a "headroom" of 60V, "2nd:1.97 3rd:1.70 4th:0.15 THD:2.60"
With the bias moved over one way or the other you will get a different amount of clean headroom and one side clip before the other. If you reduce the cathode resistor and use a value of 1.2mA you get the following, "2nd:4.91 3rd:2.26 4th:0.03 THD:5.40"
Hours of fun.
It took me a little while to get it (instructions? don't need any instructions). For power tubes the power output does not quite give what the tubes are doing, if you put a high voltage in and low primary impedance it calculates the power using the voltage and the impedance. If you shift over the bias you can have one side of the waveform clean and the other clipped. A lot of second harmonic distortion and it will give you a power out that seems to ignore that the one side is clipped and give you a exagerated power output. But the web page probably assumed you would want to have the tube center biased, something guitar amps like a Champ may not be. Other than that a fun tool.Thank you sir for taking the time to explain a little bit about how to use this amazing tool. Once again I am going to try to wrap my head around it.
That’s a cool idea! It would make an easy way to investigate octal goodness without building a new amp.For anybody who's interested in trying this out, using the same anode, cathode resistances and grid supply, there are such things as noval to octal adapters that do the wiring swap between a 12A*7 and a 6S{N|L}7. Search eBay. Adapters for octal to noval are, it seems more plentiful, available from TubesandMore and Tube Depot, for instance.
