JuneauMike
That looks like exactly the fixture I need to bias an amp. Do you measure the resistance and then install an equivalent value resistor in place to finish?I don't know if this is "right" or not -- but on a couple of ~5w SE builds I've had good luck
wiring one of those 5W ceramic resistors at a value of roughly 50ohm below spec in series
with a 100 ohm pot -- that way I can dial in any value from -50 / +50.
