5F2A build help
Discussion in 'Shock Brother's DIY Amps' started by nrogers, Feb 28, 2020.
  1. nrogers
    nrogers TDPRI Member
    DC
    Hi all,
    First time poster here. I just built my first kit, a 5F2A from Mojotone, and got a lot of help from @theprofessor's build thread.
    I've got the whole thing wired up, and am now checking voltages etc. I have wall AC at the fuse, and the right AC voltage at the tube heater wires. I also have high voltage at 4&6 on the rectifier (around 325V measured to ground for each).
    But:
    - The rectifier tube isn't heating up. I did test it (2 to 8) and it does have continuity.
    - I'm not getting any voltage at the filter caps.
    What's my next step to troubleshoot this?
    Thanks so much!
  2. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    Welcome. Great amp. Hang in there.
    Do you have a light bulb limiter? Easy to build and a really good simple tool right now.
    Is your rectifier known to be good? Can we see some nice clear pics of the PT/rectifier/filter cap wiring?
    What do you measure at rectifier pin 8 *in both VAC and VDC?*
    D'tar likes this.
  3. Tom Kamphuys
    Tom Kamphuys Tele-Meister
    The Netherlands
    As your rectifier tube is not heating up, it can not conduct the HT. That is why you measure nothing at the filter caps.
    You have thus localized your problem: The rectifier tube isn't heating up.
    You said you have the correct voltage, but can you provide us with measurement results, clearly stating how you measured. Just writing a clear log of what I did/measured alone has helped me several times (kinda like rubber duck debugging).
    Also an image might help.
  4. Tom Kamphuys
    The Netherlands
    Great minds think alike...
    ... though fools seldom differ.
    King Fan and D'tar like this.
  5. nrogers
    DC
    Sure, thanks guys. On the rectifier pin 8 has around 400 mv DC and 4.7VAC, both measured to ground.
    I did test the rectifier using my multimeter, and got continuity between pins 2 and 8.
    Here are the earlier readings:
    At the fuse: 120 VAC
    Power tube, 6.7 VAC (pins 2-7)
    Preamp: 6.7 VAC (pins 4-9 and 5-9)
    Putting a photo in my next post. Ignore the nasty glob of solder on the pilot - taking that off soon.
  6. nrogers
    DC
  7. Lowerleftcoast
    Lowerleftcoast Tele-Holic
    california
    Pin contact is always a suspect with tubes. Make sure you have clean pins and socket. Check the socket tension for each pin. Try moving/wiggling the tube about. Sometimes the pins will make contact and the filament will start to glow.
    Try another tube if you have one.
  8. D'tar
    D'tar Friend of Leo's
    WNY
    Make sure you're connected to the proper pins/terminals and your tube is then inserted properly as well.
  9. D'tar
    WNY
    Looks like belton socket heres a comparison as to my earlier post...
    Yours
    Another
  10. nrogers
    DC
    Thanks! Can you explain why it is relevant that it is a Belton socket?
  11. elpico
    elpico Tele-Holic
    Vancouver BC
    On the rectifier, whats the AC voltage between pin 8 and pin 2? Not the voltage from those to ground, the voltage with the probes on those two pins.
  12. nrogers
    DC
    Around 5V AC between 2 and 8 on the rectifier
  13. D'tar
    WNY
    Relevant that the orientation should be the same and it looks to me that you may be connected to the wrong terminals perhaps. Like pins 7 and 1 instead of 8 and 2. Also 3 and 5 instead of 4 and 6.
    Easy enough to confirm right.
    robrob and King Fan like this.
  14. nrogers
    DC
    Winner winner! Can't believe I messed that up after checking it like twelve times. Thank you! I'll resolder and report back.
  15. nrogers
    DC
    OK, I moved the various wires and got the rectifier working. Following @robrob's startup procedure, I measured the voltage at the filter caps and the preamp. Around 470 in each spot. However, I'm not getting any reading on the power tube where the OT wires link in (pin 3).
    Any advice what to try next?
  16. D'tar
    WNY
    A full set of pictures may help all to see the entire circuit and spot any obvious issues.
    I see one yellow wire coming off your rectifier toward the board connected to first filter. Is that connected under the board to the next filter?
  17. nrogers
    DC
    Sure, here you go. The yellow wire goes from the rectifier to the first filter cap, and the OT blue line goes to the next cap. I did jumper those together underneath the board. Also the pink/yellow wire from V2 to V1 is a heater wire--ran out of green cloth wire.
    Thanks guys!
  18. D'tar
    WNY
    I would reflow any joint that looks like this one. fill that void full of solder. If you still do not have B+ after that you may want to Ohm the primary (blue to red) and see whats what.
    Pick_n_Strum likes this.
  19. D'tar
    WNY
    Preparing for Hum? Where is your heater center tap. You will need an artificial one with that PT. I do not see one.
    Lowerleftcoast likes this.
  20. Lowerleftcoast
    california
    The power cord colors. Blk = hot. White = common. Green = ground. The black should go to the switch and then the fuse. When the fuse blows = no power. When the switch is off = no power. The way you have it the common is disconnected when the switch is off so there is still power to the amp.
