Am I having a brain cramp, friends, or is a 350-0-350 PT crazy hot for an amp that had a schematic B+ of 340V on 110 wall power? If I'm thinking straight, it seems like we're lucky to have voltages as low as they are here.
@0Telemetry that's refreshingly honest. Do you know how to measure bias on your amp? Are you comfortable measuring voltages? Maybe AC heater voltages (pin-to-pin as noted -- this at least isn't very dangerous) and DC voltages (pin-to-chassis) on all pins 1-3 and 6-8 in the preamp, and pins 3 and 4 on the output tubes? If so, how about measuring rectifier pins 4 and 6 for AC voltage (you can measure these each pin-to-chassis to decrease the load on your meter).
@andrewRneumann , I like your PT primary idea. For our OP's benefit, I'm thinking you're using the bigger voltage gap between these two primaries (130V) to cut down the secondary voltage coming out. 0Telemetry, let us know what you think and how you want to proceed. Oh, and re your B+ and B+1 voltages, let us ask: what meter are you using?
I should have mentioned that I know very little about what is what. So talk to me like the novice I am. But I am learning.
