5F11 build negative feedback help
Discussion in 'Shock Brother's DIY Amps' started by Paul Strat, Aug 16, 2019.
  1. Paul Strat
    Paul Strat Tele-Meister
    Muscle Shoals, AL
    D'tar likes this.
  2. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    Maybe a couple more pics showing the socket wiring and the area around the NFB? If that's the cause of the problem, there isn't a lot of detail of it in the pictures.
    Also, with the amp turned off, unplugged, and caps drained, the continuity setting on your meter is probably going to be the best tool to figure it all out. There's probably either a connection that shouldn't be there, or it's missing one that should be.
  3. D'tar
    D'tar Friend of Leo's
    WNY
    Amp off, unplugged, caps drained...
    Can you ohm the disconnected nfb feed wire to ground.
  4. Paul Strat
    Muscle Shoals, AL
    56.9 k
  5. Paul Strat
    Muscle Shoals, AL
    CF842A09-18D8-485C-B9CB-24940F56619A.jpeg ABADA248-9C08-4384-9355-649C0C8B8E42.jpeg 37C87BF0-2D31-4B05-AA95-79537CF0123D.jpeg
  6. jsnwhite619
    Georgia
    Are you sure this wire from the NFB isn't shorting to ground? It looks really close to the chassis at the cut. 5f11 nfb.png
    Nickfl likes this.
  7. Paul Strat
    Muscle Shoals, AL
    I think I found the issue.
    Good ole continuity is telling me I miswired the jumper that goes from the .02 cap to the 1 Meg PI grid. It’s going to the NFB resistor.
    Snfoilhat and D'tar like this.
  8. Paul Strat
    Muscle Shoals, AL
    Although when it was miswired by bias was spot on. Now it’s freezing cold.
    -71 and <5ma
  9. jsnwhite619
    Georgia
    Stock bias resistor was way off for me.
    I ended up with 16-17k and a 10k pot.
    Sent from my XT1585 using Tapatalk
  10. Paul Strat
    Muscle Shoals, AL
    Mine worked out with a 10k pot and the 33k range resistor. Had to drop the 10 at the bias tap down to 4.7 k. My 33k was broken and causing the cold bias issue.
    jsnwhite619 likes this.
  11. jsnwhite619
    Georgia
    My PT has two secondary options. I've run my 5f11 from <300v B+ to nearly 400v. I like the softer feel and lower output of the low voltage, but I figured out the trem & bass works better in the 365-375v B+ range on mine. They are great amps though. Amazing, rich clean tones and a can really rock out when you crank them.
    Paul Strat likes this.
