5f10 Harvard, what V1 are you running?
Discussion in 'Glowing Bottle Tube Amp Forum' started by gobi_grey, Jul 3, 2020.
  1. gobi_grey
    gobi_grey Tele-Afflicted
    clinton, ia
    Are these ever converted to a 9 pin 12a*7 socket? Or when you build them, do you typically use the 9 pin instead of the 7 pin socket? What tube do you prefer in v1?
    I see benefits both ways. I'm used to 12ay7 in V1 on tweed amps and with the 7 pin socket, you only have two choices of tubes to use.
    While we're on the subject, feel free to show off your 5f10 Harvard or clone and feel free to talk about it. I love reading what you all have to say.
  2. FiddlinJim
    FiddlinJim Tele-Holic
    Seee-attle
    Both 6AT6 and 6AV6 are pretty available as NOS and not nearly as expensive as 12A#7 tubes. 6AT6 has a similar gain as a 12AY7 and the 6AV6 is similar to 12AX7. So, I don’t see a reason to convert to a 9-pin, myself. I use the lower gain 6AT6 in mine (clone I built) right now.
    Sent from my iPad using Tapatalk
  3. schmee
    I built with a 9 pin, and later built with the original tube, but as mentioned those tubes are plentiful and cheap.
