Jerry garrcia
Hi. Did something stupid. Had nothing to do since I was waiting for some parts for a build.
I tore down my “Champ” and resoldered it all to get a better visual appearance.
When I started it all up the lamp and rectifying tube glowed like the star from the bible. Everything was silence and no 50Hz hum. The problem started when I plugged in the guitar since the amp was still silent…
All tubes glowed.
I measured the voltage at measuring point P1 (connection by C1, R13, T2 and Pin 8 from V3) and was around 0,356 VDC. More than a factor 1000 to low. Before my resoldering it was 376 VDC. P2 and P3 was of course also to low.
I measured up T1 and the VAC values was correct on both lines, yellow 5.1 VAC, Red 340 VAC and green 3,2 VAC so the Transformer seems ok.
Measured the voltage at pin 8 on V3 and in the red wire, by the connection to V3 to P1, corresponded to P1.
This made me to draw the conclusion that the problem is in ether the V3 socket or in the rectifier tube. Correct?
If so, is there a way to tell in which “component” the problem is? The whole amp has been demounted and rebuilt 3 times with the same components, except the wires to problem solving issues and “ugly appearance”.
Can the problem otherwise be downstream due to faulty components or grounding issues?
If anybody has the know how to narrow down the issue, don’t hesitate to reply even if it is my own fault for tampering with a functioning amp.
I have all the components “in stock” at home except for a 5Y3 tube and V2/V3 sockets.
I’ll include pictures.
All tubes glowed.
